1999 Chevrolet Blazer - Stereo Integrity, Ground Zero, Soundstream
15-80Hz sweep. Pay attention to the top blue lines, those were the peaks, not the red bars.
Sealed, at headrest:
5D69FC2E-775B-46A0-8358-DC8CF3EE5B28_zps
Driver's door open, in passenger kick:
7BA1E3C4-12A5-4A45-9411-200C52F71375_zps
Knew I heard that rolloff. Seems to fall flat above 43Hz or so, probably a product of small enclosure and vehicle.
Also still trying to learn the limits. Was playing decaf pretty decently at full tilt for about a minute at a time, then put on a couple tracks I have verified clean in Audacity that are damn loud and started smelling coil. Cap was hot. I'm even at -1 on the sub level (set gain at 0). Talking with Murphy and TFade, might be low electrical even though I was above 13.8V the whole time, might also be the small box. Could be fighting with box resonance.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
Interesting, tuned to whatever you find
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Wouldn't box resonance cause the sub to see less power?
I get hot at full, full tilt for several minutes straight, but at a click or two below I can go for an hour and be only warm.
You're even underpowering this thing though aren't you?
Yeah should. I need to get an impedance profile done and see what's going on.
I am at this point. So only explanation in my mind is dirty signal. Just have to learn the limits and adjust accordingly I guess.
Try a different amp?
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Don't have one. What would lead you to believe it's the amp? Or just simply troubleshooting?
Just straight guessing. I really don't know if you have a problem or not but you don't seem happy so something must be amiss? You can blame it on the box but if I were you I would not want to wreck that beast sub so I would start eliminating things and with what is going on with it...I would start with the amp. (I forget what you are currently running)
also, again i am just guessing.
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
DC 5.0k. Wired to .7 right now. I don't suspect the physical equipment right now, but still could be my gain. Don't get me wrong, I don't always smell coil. Maybe I'm simply getting happy with the volume/gain, but it doesn't make sense with the way I set my gain. On paper anyway.
box specs?
10 cubes net tuned to 24Hz. Tantric says 10-12 would be ok. It's a little in the small side, but not by a huge amount.
box specs?
i didnt read much but your concern is the roll off at 43hz?
  • Who's Online   0 Members, 0 Anonymous, 2696 Guests (See full list)
