ncochran Posted June 17, 2013 Report Posted June 17, 2013 Anyone know much about this amp? As in, is it quality equipment? I have been told that it is rated around 2400 watts 2ohm bridged, does that sound legit? I am looking at picking one up this week for around $300 and am trying to figure out whether that is a decent deal. I would be upgrading from a Hifonics brz-2100. Thanks 2006 Scion xB 2 Sundown SA12D2 Ported at 32hz 147 on non termlab (140-142 on TL) Currently in a walled 4th @ 50hz (not metered yet) Hifonics brz2100 Alpine Type-S Components Kicker 300.2 Big 3 / Skyhigh 1/0 cca Optima Blue Top 3 e8s ported at 32hz 135.1 sealed on dash @ 56hz 135.0 outlaw (I must have chosen song poorly lol) Build log 'Brandon15zzz', on 09 May 2012 - 3:13 PM, said: May have been clipping but none fucks were givin.
ncochran Posted June 17, 2013 Author Report Posted June 17, 2013 bump 2006 Scion xB 2 Sundown SA12D2 Ported at 32hz 147 on non termlab (140-142 on TL) Currently in a walled 4th @ 50hz (not metered yet) Hifonics brz2100 Alpine Type-S Components Kicker 300.2 Big 3 / Skyhigh 1/0 cca Optima Blue Top 3 e8s ported at 32hz 135.1 sealed on dash @ 56hz 135.0 outlaw (I must have chosen song poorly lol) Build log 'Brandon15zzz', on 09 May 2012 - 3:13 PM, said: May have been clipping but none fucks were givin.
HatersGonnaHate Posted June 17, 2013 Report Posted June 17, 2013 Yes it is quality equipment. And the $300 is well worth it. My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
kl0wn Posted June 17, 2013 Report Posted June 17, 2013 You're going from 2100 to 2400? You won't be able to audibly hear a difference. But to answer your question yes they are good. 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
HatersGonnaHate Posted June 17, 2013 Report Posted June 17, 2013 He'll notice less voltage drop, thus better efficiency, so there might be an audible difference. Jeff had those in his suburban running all his mids and highs. You know how loud and clear that burban is Jacob lol My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
justin0943 Posted June 17, 2013 Report Posted June 17, 2013 jump on it their a good brand it will do what it said an just a little more the manual says 2200rms x 1 2ohm so it may due 2400 if you have good electrical 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
ncochran Posted June 18, 2013 Author Report Posted June 18, 2013 Right on, thanks for the input. I am figuring this to be a huge increase in power actually. With the Hifonics, it is 2100 at 1ohm. My subs are currently wired to 2ohm, and after clamping it the other day (gains set by dmm and not oscope) I am only seeing between 700 and 900 watts between 30 and 60hz. The Cadence is rated at 2200 @ 2ohms bridged so that seems a better fit. I am guessing that my actual power will almost double. And if it is a more efficient and better quality amp, then it seems like a no brainer in this case. Thanks much! 2006 Scion xB 2 Sundown SA12D2 Ported at 32hz 147 on non termlab (140-142 on TL) Currently in a walled 4th @ 50hz (not metered yet) Hifonics brz2100 Alpine Type-S Components Kicker 300.2 Big 3 / Skyhigh 1/0 cca Optima Blue Top 3 e8s ported at 32hz 135.1 sealed on dash @ 56hz 135.0 outlaw (I must have chosen song poorly lol) Build log 'Brandon15zzz', on 09 May 2012 - 3:13 PM, said: May have been clipping but none fucks were givin.
TaylorFade Posted June 18, 2013 Report Posted June 18, 2013 Got electrical? 2k worth of A/B powa. Super solid amp, but it's going to be a pretty good jump in draw from a "2k" HiFonics making 700-900w.
ncochran Posted June 19, 2013 Author Report Posted June 19, 2013 Big 3, stock alt and optima blue top up front. Looking into battery upgrades for the rear, just don't want to spend much on it until I find that I need it. I hold pretty steady around 13.2 or so right now on decaf music. If I get it and can't keep it in the upper 12s I will definitely make changes as needed. 2006 Scion xB 2 Sundown SA12D2 Ported at 32hz 147 on non termlab (140-142 on TL) Currently in a walled 4th @ 50hz (not metered yet) Hifonics brz2100 Alpine Type-S Components Kicker 300.2 Big 3 / Skyhigh 1/0 cca Optima Blue Top 3 e8s ported at 32hz 135.1 sealed on dash @ 56hz 135.0 outlaw (I must have chosen song poorly lol) Build log 'Brandon15zzz', on 09 May 2012 - 3:13 PM, said: May have been clipping but none fucks were givin.
justin0943 Posted June 19, 2013 Report Posted June 19, 2013 take the blue top out I heard nothing but bad things about them and run xs or Kinetik battery and step up the alt to 250amp and should be good if not might have to add 2nd battery but shouldn't 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
