alaskanzx5 Posted June 27, 2013 Report Posted June 27, 2013 so it more freq at the higher freq? like in the 35-40hz range? is it slot port or round port? have a different box or a friend with a box you can put it in? i would try a different box just to see if that changes it. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Kyblack76 Posted June 27, 2013 Report Posted June 27, 2013 no dust cap on those drivers SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
DylanBunch Posted June 27, 2013 Author Report Posted June 27, 2013 Yeah I have a different box. And kyle - i guess dustcap is the wrong term... but the black aluminum circle that says rockford fosgate t2 isn't thecone. Its a lot like the skar vvx v1 if you've seen those 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
DylanBunch Posted June 27, 2013 Author Report Posted June 27, 2013 Its a slot port btw 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
alaskanzx5 Posted June 27, 2013 Report Posted June 27, 2013 box volume is on par where it should be then. i would still try another box just to see what happens. you might just be s o l t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
CRudy Posted June 27, 2013 Report Posted June 27, 2013 I feel like I've heard people call it an "inverted dustcap" but then again I'm probably wrong. Also my friend has an alpine with the same kind of "dustcap" and it would make a rattling noise or something at a high volume, so he took it back to bestbuy (where he purchased it from and had it installed) and they said he blew one of the voice coils? I'm sure your situation is different but i figured i'd put in some input haha
alaskanzx5 Posted June 27, 2013 Report Posted June 27, 2013 i had a t2 12 that i had a similar issue with. had it in a 3-3.5 cuft box ( dont remember for sure ) tuned to around 40hz. turned out it was a blown coil and i didnt realize it until i put a t1500.1 on it (big mistake in such a big box but live and learn) burnt that sub up real bad but oddly enough it was playing for a good 2-3 months like that until i put it in a 2cuft box tuned to 40hz slot port. after about 3 months in that box it started smoking like crazy. got it warrantied. the local shop i got it from just traded me out as rockford tech told them to. thats my own exp but was in way to big of a box for the power i was running. might not be the same issue your having but if it is i hope the place you got it from will warranty it. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
DylanBunch Posted June 27, 2013 Author Report Posted June 27, 2013 Just put it in a smaller, higher tuned box. In a little bit I might go drive around and check it out. Ill let you guys know 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
dfoland93 Posted June 28, 2013 Report Posted June 28, 2013 ??? The spot with least resistance LOL. I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring. how many poeple work there 3 or 4 lol At crescendo HQ? probably 2-3 At the sweatshop in china? 30,000 children No Engine
DylanBunch Posted June 28, 2013 Author Report Posted June 28, 2013 sorry. yeah its still happening.. all frequencies. guess im sol 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
