DC Sound Lab
yeah i dont think its that easy to clip a 400rms signal so hard that it makes a 2000rms woofers coil start to smoke.
if the smell goes away after a few days/a week, then its just the excess glue burning off and its nothing to worry about.
Edited by Kranny
the xl's lvl 5's and lvl 6's will give off a glue smell when they are breaking in
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
If you aren't giving the sub enough power to get the coil moving in the gap so that it will properly cool and you are clipping the signal, that could cause the smell.
Or coils are out of phase .. Double check wiring
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
smells like an avg woofer getting too much power I don't think the clipping is too bad
lolwut? There's guys on this forum giving XL's 8 to 10 times the amount of power he is, cleanly.
why are you only giving the sub 400 watts? arent they rated like 2000-2500 rms? lol
but i guess just make sure your not sending a clipped signal and maybe make sure your amp isint getting really hot too..
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
  • Who's Online   0 Members, 0 Anonymous, 1080 Guests (See full list)
