heightzbest562 Posted July 5, 2013 Report Share Posted July 5, 2013 I was blasting some music for about 30min I was playing a decaf version of low frequency by dj billy e ..when I start hearing. A rattle with the bass playing ..I let it cool for a while. Then I started playing again after about 10 min of playing it started rattling again. this time I was playing faded by tyga ... I was running xl 18 m2 a saz4500 @1ohm with stock electric. And gain about half way .bass boost all the way down also on the radio I had the bass eq turned down too Quote Link to comment Share on other sites More sharing options...
Raptorman Posted July 5, 2013 Report Share Posted July 5, 2013 You're running over 4.5k to a DC XL? I'm not sure how much you can overpower those but that sounds a bit excessive. Quote 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies. Link to comment Share on other sites More sharing options...
CJ18 Posted July 5, 2013 Report Share Posted July 5, 2013 4500w amp on a 2200w sub. First mistake. Gain about half way??? How did you set your amp to know if you are sending a clipped/distorted signal to the sub? Second mistake 4500w amp on stock electrical.....ouch Quote Link to comment Share on other sites More sharing options...
will77530 Posted July 5, 2013 Report Share Posted July 5, 2013 and this is why dc has a bad rep Quote Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted July 5, 2013 Report Share Posted July 5, 2013 wow, by what you posted you were doing quite a few things poorly and wrong. double rms, shitty electrical, gain at half (whatever that means). Half gain doesnt mean half power. If you gain is just over what it should be, you can be sent into heavy clipping. The rattle you hear i think is bubbling of the coil. Had it happen to me on a level 5 m1 when i clipped it to shit. The former bubbled out from heat build up and it not being able to escape the flatwinds of the coil, so it bubbles out the former and causes it to rub on the pole. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
CJ18 Posted July 5, 2013 Report Share Posted July 5, 2013 and this is why dc has a bad rep Couldnt agree with you more. If I could like that comment 1000x I would! Quote Link to comment Share on other sites More sharing options...
