lilwillywilly Posted July 6, 2013 Report Posted July 6, 2013 Alpine mrp-m650 Alpine type R, d4, wired at 2 ohm Here's the deal. Amp powers up fine, but will not power sub. Sometimes if volume is up the amp will kick on, not often though. But.... If I turn the system on, then disconnect the speaker wire at the box, wait a few seconds and hook it back up, it plays fine. I'm lost, and getting out and popping the hatch to turn my sub on is getting pretty old. Any ideas?
big dee Posted July 6, 2013 Report Posted July 6, 2013 Im try different subs . It almost sounds like a sub issue to me
Skullz Posted July 6, 2013 Report Posted July 6, 2013 Check all the wiring cause you may have a pinched wire somewhere or something isn't connect tightly enough, so give everything a nice tug and see if something is loose or pinched. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
justin0943 Posted July 6, 2013 Report Posted July 6, 2013 idk could be something loose in the amp 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
armykyle1 Posted July 6, 2013 Report Posted July 6, 2013 Bad lead? TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting
