bigmescan Posted July 6, 2013 Author Report Posted July 6, 2013 Yes I've switched rca's... Switched amps. Only thing I have switched is the HU... The problem goes away as soon as I replace PAC and maybe a week or a month problem comes back. Longest its gone is 2 months. An installer I know was thinking the resistors in the PAC get hot from the 5v being produced from HU and wearing it out. He said its just a theory cause he's dumbfounded as well. Right now I have the PAC unhooked and no rumble at all. The only way the rumble get louder is when I turn the nob up but goes away at max. SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
AMI CUSTOMS Posted July 6, 2013 Report Posted July 6, 2013 There isn't resistors in the PAC, it a rotary POT, variable resistor. It should be about to carry upwards of 32 volts AC, depending on the watt rating. AC signal thru RCA's is low amperage so voltage could be crazy high and not hurt that PAC device. Could just be the PAC device all together may need to look at your mounting location or doing something else with it. I know plenty of people who use them and have no problems. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
shoulinpanther Posted July 6, 2013 Report Posted July 6, 2013 Sounds like interference of the electrical kind, make sure your RCA are insulated and the pac1 wires as well. And if they need to be rerouted away from power and ground wires do that. Of course this is just my guess.
95neon_thumper82 Posted July 6, 2013 Report Posted July 6, 2013 I'd say fuck the pac. control your bass from the headunit. that's just me though! <img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800"> Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log!
bigmescan Posted July 6, 2013 Author Report Posted July 6, 2013 Appreciate the help guys. Rca's are on pass side and power on driver. I need the bassknob when wifey drives with me. I'm ready to just rip out all wiring and start over. Bassknob is flush mounted to a piece of plastic. All you see is the knob. I've switched 3 sets of RCA's. Always have probs when I own a ford. SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
ChevyBoy95 Posted July 6, 2013 Report Posted July 6, 2013 Ok guys here's the issue I'm having. I don't have a ground loop issue. I have a rubbling just from the subs. I have an eclipse 5030 5v preout. Doesn't matter what amp I use the problem still persists. I'm on my 3rd pac1 bassknob. When I'm at 0 on know rumble goes away. If I'm at max on bass knob problem goes away. Anywhere from minimum to max on the knob I get the rumble. Could the 5v preout be to much for the bassknob. This problem happened when I was running 3 sa8's off a rf power 1000.1 amp and my temp setup is a 500.1 JL amp on 2 w0 jl 10's. it is the knob. mine does it on my mids highs amp on the channels i have the pac lc-1 on, but regardless, the one i have on my sub amp doesnt do it. I think it is just the pick of the lot. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
bassaddiction Posted July 6, 2013 Report Posted July 6, 2013 Appreciate the help guys. Rca's are on pass side and power on driver. I need the bassknob when wifey drives with me. I'm ready to just rip out all wiring and start over. Bassknob is flush mounted to a piece of plastic. All you see is the knob. I've switched 3 sets of RCA's. Always have probs when I own a ford. do u take it apart when u flush mount it? allso u could run new rca to it over your seat so it away form ground see if nosie stops. i think your just over useing it and there cheaply made
bigmescan Posted July 6, 2013 Author Report Posted July 6, 2013 I don't take it apart when I mounted it... Just push know thru hole and put screw on.. I've done the RCA's over the seat and does the same things. There's no way that all 3 PAC's are bad.. If so I need a diff brand of bass knob. SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
bigmescan Posted July 6, 2013 Author Report Posted July 6, 2013 Hate my damn phone. Know is Knob SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
95neon_thumper82 Posted July 7, 2013 Report Posted July 7, 2013 Hate my damn phone. Know is Knoblove androids man what would happen if you were to put a toggle on your control line to the bass amp? just leave the bass amp off when she's with ya then soon as you hit the eject button on her seat you turn the bass amp on and enjoy the ride like its intended? this is what I did... it works perfectly... even got the red lighted toggle so I can see when I leave it on at night edited for : you could even run a fresh hot line from the battery... with an inline fuse ( my inline is 1 amp) the to the lighted toggle then to the control on the amp... trust... its nice for them pesky police too <img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800"> Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log!
