Stephen Dunnington Posted July 8, 2013 Report Share Posted July 8, 2013 I just bought all my wood, glue, nails, tools and a lovely jasper 200. This is my first build so I just want to make sure I'm doing things right, I'm placing a 15" DC Level 5 in a box that is 16" heigh, 24" width and a depth of 20". After doing the calculations it says that I have 8.8 cubic feet and have to use a port of 5" in width and 40" in length in order to be tuned at 30 HZ. Now I'm putting double layers of MDF so I don't have to brace it, I'm also fiberglassing it so would I have to put 1.5" for thickness on a calculator such as <a data-ipb="nomediaparse" data-cke-saved-href="http://reaudio.com/?%20If%20someone%20could%20make%20sure%20I" href="http://reaudio.com/?%20If%20someone%20could%20make%20sure%20I" m%20not%20messing%20anything%20up,%20it%20would%20mean%20my%20whole%20pocket%20to%20me%20:d"="">http://reaudio.com/? If someone could make sure I'm not messing anything up, it would mean my whole pocket to me edit: width is 24, seeing how I only have 2x4 sheets of MDF. Link to comment Share on other sites More sharing options...
ToNasty Posted July 8, 2013 Report Share Posted July 8, 2013 8 cubes for a 15? Way way to big. You want net not gross ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
Stephen Dunnington Posted July 8, 2013 Author Report Share Posted July 8, 2013 8 cubes for a 15? Way way to big. You want net not gross So what would be ideal for something in a trunk? Link to comment Share on other sites More sharing options...
Stephen Dunnington Posted July 8, 2013 Author Report Share Posted July 8, 2013 Here are the subwoofers spec 12" 15" 18" Mounting Depth 8.5 9.75 11 Mounting Hole Diameter 11" 14" 16.75" Outside Driver Diameter 12.5" 15.7" 18.5" Weight 81.5lbs 82lbs 84lbs VC Diameter 3.5" Flat 8 layer 3.5" Flat 8 layer 3.5" Flat 8 layer Displacement .20³ ft .24³ ft .26³ ft Magnet Weight 79.5lbs 79.5lbs 79.5lbs Power Handling RMS/Peak 3000/5000 3500/5000 3500/5000 Impedance (Ohm) D.7/D1/D1.4/D2 D.7/D1/D1.4/D2 D.7/D1/D1.4/D2 Sd 494.00 cm² 791.00 cm² 1159.00 cm² Suggested Sealed N/A N/A N/A Suggested Ported 1.5³ ft 3.75³ ft 6³ ft Link to comment Share on other sites More sharing options...
bbeljefe Posted July 8, 2013 Report Share Posted July 8, 2013 Sixteen by thirty by twenty is only 5.6 cubes gross. Then you have to consider displacements and material thicknesses. I don't know where or how you got 8.8 cubes but you don't have 8.8 cubes. You have more like 4.5 cubes net... if you're only doubling the material on the baffle. Are they suggesting 80" of port as well? Sorry to seem thick about it but the link you provided sends me to Re's products page and not a driver specific page. Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe Link to comment Share on other sites More sharing options...
Stephen Dunnington Posted July 8, 2013 Author Report Share Posted July 8, 2013 Sixteen by thirty by twenty is only 5.6 cubes gross. Then you have to consider displacements and material thicknesses. I don't know where or how you got 8.8 cubes but you don't have 8.8 cubes. You have more like 4.5 cubes net... if you're only doubling the material on the baffle. Are they suggesting 80" of port as well? Sorry to seem thick about it but the link you provided sends me to Re's products page and not a driver specific page. I edited the post and forgot to change the cube ;p and here's the site with specs http://www.dcsoundlab.com/level5.html Link to comment Share on other sites More sharing options...
Stephen Dunnington Posted July 8, 2013 Author Report Share Posted July 8, 2013 Update: My sub is recommended 3.75cu and when i did W-24, H-16, D-24 with a 3" port it came out to be 3.9cu and 31.5Hz, I'm trying to get low over here, can anyone else jump in on this? Link to comment Share on other sites More sharing options...
slowfkncar Posted July 8, 2013 Report Share Posted July 8, 2013 That enclosure seems fine. 3.9 @ 31.5 I'm assuming your sub displacement is .21 which is 3.69 net probably around 32hz. Keep this manufacturer rating and the thermal/mec specs will still be the same. Link to comment Share on other sites More sharing options...
