Changing thread: Help me design the system i had questions about!
Okay so im plannin out a shell design for my trunk and i have decided to lay down 2x4's / OR a 1/2 thick piece of mdf.
First question is, since this is a relatively low power build, (2k>) which would be better to use as a base 2x4's or MDF?
Second question... I have 1 and only 1 place to ground my amps inside the trunk, and its right behind my seats. So how should i approah this because i am going to have 2 amps, and an extra battery. So i SHOULD ground the battery, then geound the anos off the battery, RIGHT?
Third question. Since i only have 1 spot to ground and no other bolts in my trunk area, how am i suppose to mount the MDF in the trunk? Do i just lay it over the sound deadener im putting in or what? Is it absolutely needed to bolt the wood to the floor, then the box to the wood?
Any suggestions and answers are welcome! And if you need more info let me know!
2007 Volvo S40 2.4i (no turbo :( )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
I only have 1 answer, the others I do not know of but I would like to learn for myself. Your ground situation, is the behind your seat the seat belt nut? That is very bad to use, try and find a bolt anywhere that goes directly to your frame. If not, do 2 runs from the front to back, one for positive and one for ground.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
No no no its not the seat belt nut, it goes to the body of the car! Lol. I have a unibody car. So nope, no frame grounds. I have the best possible ground in my trunk i know thag much. Lol.
ok good, yeah seat belt bolts are terrible, you got the grounds down. I was thinking about your first question, and I really don't know. 2x4's would be sturdy as hell, but it possibly could be way overkill and cut into your max dimensions, My system which is a hatch, I just have a 3/4in peice of plywood underneath my box, over the rear wheel well.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
I was also thinking the 2x4's could be a littke much. i am trying to save alot of space forsure. So did you bother with bolting the plywood or your box to the floor?
bolting the box down will stop box from shifting when you brake accelerate and steer. so number 1 its for safety.
nummber 2 when subs playing, they may be able to move the box when they move so that may gain you dbeeez due to the fact that the box isn't working against subs.
id bolt down. i used 1/4 inch birch in my trunk. if you have a spare tire or something to support it in the middle, 1/4 inch works. if you can fit .5inch do that then.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
For my car, perviously I had it set up with a 6x9 box wedged on either side of my box, so it never shifted from the car moving so I no didn't attach it to my false floor. however, I now have my speakers mounted to the sides of the box so there is nothing holding it firmly in place, but it doesn't seem to move that much. I was thinking of adding some screws to the board around the box to help keep it in place just to make sure.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Just because thats the only bolt you see factory doesnt mean you can make your onw...get creative
Very true.
Thanks for the suggestions you guys. I will try to mock up something and think of which angle to take next
  • Who's Online   1 Member, 0 Anonymous, 533 Guests (See full list)
