bass knobs
Craig
depends on the brand...some amps let you use a splitter and some dont.  Some, like my RF amps use one knob for up to 100 amps (if you had that many)
for my older RF amps i had a 8 way "coupler" to do the trick.  I wouldnt want two bass knobs your subs would never move at the same time they would be all over the place.
Follow my Tweet (Twitter)
I use the
STEREO REMOTE VOLUME CONTROL
N-22V    $21.50
Order N-22V  .:| Here |:.
The N-22V is a passive stereo potentiometer designed to control the signal level feeding an amplifier, equalizer, electronic crossover, etc. The N-22V has a stereo pair of RCA inputs and a stereo pair of RCA outputs. It's important that the inputs and outputs be connected correctly. The outputs must feed and amp and the inputs must go to the source (i.e. deck.) That's it. When the black knob is rotated clockwise, the signal increases up to the maximum output of the source. When the knob is rotated counter-clockwise, the signal decreases all the way to zero volts (system mute). The N-22V can be installed under the dash, in a console, glove box, or hidden away.
http://www.davidnavone.com/linedrivers.htm
yeah. im running 2 subs and 2 amps as well. a sub on each amp. they are the mtx 7801's. the bass knob plugs into the amp with a headphone type jack. do you know where i can get a splitter for one of those so i can run one bass knob for both amps?
18's in a wall to come....Its not all about the posts....check the member #...
