Retrofitting and BiXenon Projectors
the retrofit source is a good place to get everything. the guys there are really helpful too.
also just thought of this, but getting something like this:
http://www.theretrofitsource.com/product_info.php?products_id=227
will be a LOT easier to do as the projector fits in the bulb housing. fitting and mounting the projector in is half the battle. i have the FX-R projectors and fitting those compared to the ones i linked is a whole different battle
same ones I have only the 6.0 version. They are extremely easy to work with. no need for any cutting or anything.
*Hummer H3*
HeadUnit
Pioneer AVH-X4600BT
Mids and Highs
8-CT Sounds Pro 8" 8ohm
4-CT Sounds Pro Tweeters
Amplifiers
1-CT Sounds 125.4
1-CT Sounds 60.4
1-CT Sounds 7000.1
Electrical
3-Runs of 1/0 CT Sounds
8-XS Power D3100
3-Iraggi 300 amp Alternators
Subwoofers
4-SQ Hdc3 15" Subwoofers
(Soon to be 4 15" Ct Sounds EXO)
well those are the ones I am looking at now. That sure is more reassuring that I won't have do much cutting. I just wish they had 8k bulbs, but hopefully I will still get the color I want since they will be in projectors now. Too bad the halos have to be an extra 50. That is one thing I liked on the other kit
remember what I said about halos though, you can't get them to be halos for during daytime and then halo and hid during nighttime driving without adding a switch and some wiring. You will always have halos and hid's by tapping into the stock wires for your headlights which to me are pointless. I would only get halos if I were to use them with DRL lights like we talked about on FB otherwise I would just stick to plain HID projectors with no halos for a setup like mine where I disabled the DRL's.
I have two positions on my switch for lights. First click turns on the orange lights/side marker lights and rear running lights but not headlights, second click turns everything on including headlights. If I were to tap into the wire that turns on the side marker lights for the halos, they would be on with the orange lights wouldn't they?
Either way, will probably just be projectors anyways. But I was still wondering for reference.
^^ correct. That's how it works on my car anyway.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Ohh yeah good call, I didn't even think to run it for the running lights. Yeah you can tap into the +12v feed for your constant +12v running light circuit. Just make sure you get the right wire and don't grab the wire that gets +12v when the turn signals are on, the last thing you need is the halo flashing with your signals lmao.
thats actually how those porsche and audi's are wired, but with the switchback affect. white to orange. Looks cool in that instance, but never saw halos with the switchback.
*Hummer H3*
HeadUnit
Pioneer AVH-X4600BT
Mids and Highs
Amplifiers
1-CT Sounds 125.4
1-CT Sounds 60.4
1-CT Sounds 7000.1
Electrical
8-XS Power D3100
Subwoofers
Switchback led's are the shiznit. I saw someone online with an envoy that had switchback led's for the turn signals in the front lights. Normally they were white then they would turn orange when the signals were on. Totally awesome
  • Who's Online   0 Members, 0 Anonymous, 1572 Guests (See full list)
