DC Sound Lab
vidz :blink:
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
not to knock this thread, be negative, say dc subs suck, or start an argument in any way.... but if you put more power to both subs... check the numbers then... all u did was put the max power to the dc and a little more than half to the dd. sure dc is a good sub, but when comparing to dd u need to add more power to optimize results
3850 is ideal for a 9515 daily
so basically it took tripple the rms of a dc sub to match the stated rms of the DD i wonder what the score would be if the dd's rms was trippled hell even doubled
MMM BASS OATS..ITS WHAT I HAVE FOR BREAKFAST
2 AudioQue HDC3 18'' subs
Rockford Fosgate T1 6.5 mids
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Pioneer Premier DEH-P490iB
" Shit I can roll a blunt better than those bitches in Havana!"- Uncle Elroy
well i was putting it in a nicer fashion... but yes.
I meant I was unspecialized in DD. B)
i know, i was filling you in :P
Im sure with triple that amount of power The LV4 would be a very unhappy woofer,and the 9500 would put a bigger gap between them. I only stated what the results were at that power level 3850 watts , The 9500 is alot bigger sub that is capable of taking alot more power, never said it wouldent ;) For a test with more power a LV4XL would be a more suitable woofer to compare, there about the same size and power handeling but a 9500 and LV4 is all I had at the tie, I tested them and posted the results, nothing more
Edited by WCA Rusty
DC AUDIO
Phone Number
1(855)SPL-DBZZ
Built by Competitors, for Competitors.
Dont want things to be took the wrong way again rusty, but you said the lvl 4 was just a couple tenths behind the dd, did you use the same power for that test as above for both subs?
If so do you think that the DD sub would of performed better with more power then what was used and end up being a little louder?
  • Who's Online   0 Members, 0 Anonymous, 6935 Guests (See full list)
