Help! Launched sub 7 days before heat wave!
Like I told you on facebook Jeff. Two Sundown X-12's Open Box from Carstereogiant. $600 shipped.
yeah, because the x's have stood the test of time, and have a bullet proof reputation. (like the one with the unglued spider landing at the south carolina show yesterday)
Oh heeeeere we go.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Ahhh okay I see what you're saying. You can't pull the panel while you take the sub out?
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
good to know....
anything else i should know? im looking for 1000 watt rms+ subs that are 12 inch model. Im gonna look more into the xfl's local... any other suggestions?
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
FOAM IS A BITCH my friend lol... if i did pull the panel, and the beauty panel with carpet (down to the metal behind those things) I MAY get 1 more inch.. maybe 1.5 inches. but if i did pull those apart it would be a bitch. id rather not do that if i can avoid it.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
good to know....
yeah, dont go with stuff that is brand new on the market with 1,000 people going on about how good it is and its barely even made it out there yet.
Owner of BigAss Ports
12" AA chaos should be under 600 shipped
trying to get playing by this friday.
lets try it this way. WOULD i regret buying those xfl's? im not sure yet if they are dual 4 or dual 2... dual 2 would mean id have to run .5 ohms. dual 4 means id have to change how i wire it (not too big a deal) and then run them at 1 ohm.
Would they take a sk2500? i hold around 13 volts full tilt.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
The motor can be reset and sub reconed...psi resets and you can order a recone from Skar.
very good suggestion. sounds like i should ask PSI what sup. wonder if they could just recone both? Or should i just recone a single sub and leave the working one, WORKING.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
edit, they are dual 2 XFL's. so id have to run .5
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
  • Who's Online   0 Members, 0 Anonymous, 712 Guests (See full list)
