L-Port enclosure request for Sundown X-15
-X-RaTeD-
Joe X, or anyone,
I am looking for a box design for my X-15. L-Port, tuned ~28-32Hz.
The dimensions that I have to work with are 32"W x 18"D x 16"H.
I hope that it will fit within the space that I have, but if not, could you let me know what tuning would allow it to fit?
When I hear music, I fear no danger. I am invulnerable. I see no foe. I am related to the earliest times, and to the latest.
~Henry David Thoreau
About 1600 watts, 1Ohm
Double baffle will be absolutely necessary. Id say you are RIGHT on with external dims, give our take an inch or two. Probably a 3" wide port and around 20" of port length. Not sure since I'm not running your numbers exactly, just pulling from my head. I'll bet I'm close though.
Thanks I appreciate it, that sounds good.
I could do 18"H and 20"D if absolutely necessary, but I am trying to save room to mount the amp somewhere other than on the enclosure this time.
I'm not in front of my computer right now, or a pad and paper to run the numbers. Someone else may chime in hopefully and help. If not PM me and I'll get you straightened out.
Disclaimer: Don't take these specs as gospel, i don't have jack for info on the x-15, no displacement numbers, no recommended enclosure size or anything. So this is just a ballpark using a best guess.
edit: just saw the tuning you wanted, adjusted.
I have seen t/s parameters for prototypes of these subs but nothing official regarding production units, I would get someone at Sundown to issue a recommendation, t/s parameters or whatever, the height of the box should be 16 1/2"H at least if this is for a trunk car. The jeezy stuff may not play that great on 37Hz but then again who knows what you listen to.
it's 32hz. Please read. I mean, you post 20 minutes after i edited.
My bad, here are the spec's from Jacob,
X-15 D2
1250 watts RMS
Re : 3.68 ohms
Fs : 20.51 Hz
Qes : 0.42
Qms : 4.81
Qts : 0.39
Le : 4.00 mH
Sd : 729 cm^2
Vas : 107 L
BL : 21.79 NA
Mms : 422 g
Cms : 142 uM/N
Sens : 85.17 dB 1w/1m
  • Who's Online   0 Members, 0 Anonymous, 512 Guests (See full list)
