ajb714 Posted July 27, 2013 Report Posted July 27, 2013 i need some serious help, I am so unfamiliar with ohms and what not. but anyway the amp only has 1 plug in for negative, and 1 plug for positive, but I have 2 subs. what wire set up do I need? I have heard about parallel, series, and both. im confused. please help me.
Reed Farrar Posted July 27, 2013 Report Posted July 27, 2013 im sure your amp is 1 ohm stable and if your subs are 4 ohm you can wire them to 1 ohm to get the full power out of your amp. but you have to make 100 percent sure of the ohms of your subs and what ohm your amp is stable at. go to this link you this will tell you what you need to know. http://www.crutchfield.com/ISEO-rgbtcspd/learn/learningcenter/car/subwoofers_wiring.html your amp is one channel just in case you didn't know. 1 pos and 1 neg is a mono block amp.
Watch the bass Posted July 27, 2013 Report Posted July 27, 2013 RF give some serious wiring help http://www.rockfordfosgate.com/rftech/woofer_wizard.asp "in the abundance of water, the fool is thirsty" Bob Marley
