mgameforever01 Posted July 28, 2013 Report Posted July 28, 2013 I'm going to be getting 2 12 inch dc audio level 5 but idk what amp. This will be in a 2012 ford fusion with dc 270 Amp hoa a min of 4 xs power 3100,s. I was thinking of Mabey dd audio m4a, thinking of the dc audio 7.5k but I don't want to over do it. I'm open to any suggestions, budget about 3000$ thanks in advance for any help.
Watch the bass Posted July 28, 2013 Report Posted July 28, 2013 You have 3 K, get a DC 7.5 and a scond H/O alt, + all the instalation uses and your money is spend. "in the abundance of water, the fool is thirsty" Bob Marley
hazestorm23 Posted July 30, 2013 Report Posted July 30, 2013 SKAR Audio SK-3500.1D they are about a grand each so you can easily get 2 they do more than rated you can check the YouTube test they did on it just recently
Guest Posted July 30, 2013 Report Posted July 30, 2013 SKAR Audio SK-3500.1D they are about a grand each so you can easily get 2 they do more than rated you can check the YouTube test they did on it just recently yeah...let not recommend a 3500w amp that makes less power than their 2500w amp.
hazestorm23 Posted July 30, 2013 Report Posted July 30, 2013 So that's why It did over 3900 with less than 12 volts? And its his choice I made a suggestion you came here to start drama. How about you just make a suggestion of an amp and then go on about your day... peace
Guest Posted July 30, 2013 Report Posted July 30, 2013 So that's why It did over 3900 with less than 12 volts? And its his choice I made a suggestion you came here to start drama. How about you just make a suggestion of an amp and then go on about your day... peace uhh..okay. that's why chillmasterwill swapped his 2500's for 3500's and he got quieter.
Kyblack76 Posted July 30, 2013 Report Posted July 30, 2013 DC 9k or 10k on those 5's SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Guest Posted July 30, 2013 Report Posted July 30, 2013 I said good day sir. who are you, fez from that 70s show? woofers are rated 3500 a piece. sundown NS-1 DC 7.5 american bass vfl 750 2 soundqubed 3500.1's hows that for suggestions? lol.
Kyblack76 Posted July 30, 2013 Report Posted July 30, 2013 ^^^ like those choices.. depending on where you wire down to... the ball is in your court... EDIT- id like to see more of the xfire 8k.. thing is beast as hell SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
