Diesel_Nuts Posted August 2, 2013 Report Posted August 2, 2013 i'd much rather run optima then kinetik after all the horror stories i've seen/heard about. I'm currently running my DC3.5k at 1ohm on a g34 red top with a stock 180 amp alt, the lowest I drop at or around box tuning is mid to high 12's, now If I try to play higher bass like 45hz+ I instantly see high 10's lol, impedance rise is a real bitch at tuning. horror stories?? like what? If anything, i've heard horror stories about the new yellow tops......i've heard of them dying on folks within months of having them Kinetiks should last 5 + years as long as you have a decent charging system and occasionally put it on a dual-stage tender/charger but then again, there always will be bad apples in a batch.....i wont hate on optimas, i just prefer Kinetik due to my good experience with them. XS batts are pretty good too from what i hear though i've never used em 1984 Mercedes-Benz 300D (5-speed) Alpine Type-S Mids/Highs; Fli Audio Tweeters Alpine CDE-143BT Bluetooth CD/USB/iPhone Headunit Alpine MRP-F300.4 Audiopipe 1500.1 mono Sundown Audio SA-15d2 (5.2 cu ft. ported box, tuned @ 35 hz) Kintetik HC-1800 Watt Power Cell Battery [KnuKonceptz 1 ga. Power Wiring USACI outlaw - 143.9 db
Skullz Posted August 2, 2013 Report Posted August 2, 2013 Your least expensive option is this battery. http://www.remybattery.com/deka-intimidator/9a34m-ct-agm-battery.aspx EDIT: Kinetics have a bad tendency to swell and leak all the gas out causing them to fail way too soon, there have been a few local shops that once carried them until they began having problems to the point of losing sales from all the problems they were having. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Karkov Posted August 2, 2013 Report Posted August 2, 2013 What vehicle has a stock 180 amp alt? lol Use 1/0 OFC wire. =) 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
SGT_76 Posted August 2, 2013 Report Posted August 2, 2013 Here is Remy's group 31 Deka...http://www.remybattery.com/deka-intimidator/9a31-agm-battery.aspx And for local "rebranded Deka 9a31" options look at first post here...http://www.stevemeadedesigns.com/board/topic/170962-deka-9a31-options/ Another option if you don't mind the possibility of getting stuck with the "Crescendo wait" when they're not in stock...http://store.crescendoaudio.com/crescendo-logic-f-31hp/ Personally from my own research I like XS Power, but you have to be willing to pony up some cash. Good luck and hope this helps.
Diesel_Nuts Posted August 2, 2013 Report Posted August 2, 2013 Your least expensive option is this battery. http://www.remybattery.com/deka-intimidator/9a34m-ct-agm-battery.aspx EDIT: Kinetics have a bad tendency to swell and leak all the gas out causing them to fail way too soon, there have been a few local shops that once carried them until they began having problems to the point of losing sales from all the problems they were having. really? never heard that..... but actually since my license is currently revoked and im not driving my car as much --other than letting it run in my garage - i am interested in investing in a 2 stage battery charger for the Kinetik (dry cell) do you have any recommendations? I think i'll make another thread on this subject altogether 1984 Mercedes-Benz 300D (5-speed) Alpine Type-S Mids/Highs; Fli Audio Tweeters Alpine CDE-143BT Bluetooth CD/USB/iPhone Headunit Alpine MRP-F300.4 Audiopipe 1500.1 mono Sundown Audio SA-15d2 (5.2 cu ft. ported box, tuned @ 35 hz) Kintetik HC-1800 Watt Power Cell Battery [KnuKonceptz 1 ga. Power Wiring USACI outlaw - 143.9 db
Pro7 Posted August 2, 2013 Report Posted August 2, 2013 What vehicle has a stock 180 amp alt? lol Use 1/0 OFC wire. =) My Chrysler 300 does and the chargers too. Some trucks come with dual alts from the factory now! I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
96saturnsl Posted August 2, 2013 Author Report Posted August 2, 2013 the kinetik i have is just a hc600 diesel if it still holds a charge ( been sittin a bit ) ill sell it to ya. i have no use for it. i can get a decent xs batt for 225 where i am. i used to work for a audio shop and i get a discount still skullz i dont think that 9a34m is gonna be enough power for 2500 watts lol. ill be running the 2 fi xs on about 1500-1700 rms. according to my enclosure designer the box will be a little small for the subs so that much over power wont hurt. its gonna be 5^3 with 81 cubic inches of port tuned to 32-34 hz. the subs will get around 1.5^3ft each. i am gonna ask about the enclosure on here tho. anyways, i was looking at a xs d1200 anyone think that will do the trick?
Guerra33 Posted August 2, 2013 Report Posted August 2, 2013 I have had my d1200 as a starting Battery for a while now and i love it. Great battery but i just wish i went bigger because who doesn't like more power lol. i recommend the D3400 for around an extra $50 or so.
96saturnsl Posted August 2, 2013 Author Report Posted August 2, 2013 ok. so with my stock batt up front and a d3400 in back i should be ok with the small power in running correct? i can get a d3400 for $235
Guerra33 Posted August 2, 2013 Report Posted August 2, 2013 What is your stock battery upfront? Many don't recommend mixing wet cells and agm style batteries because of the different charging or resting voltage but I have no experience doing it to tell you if its fine or not. And good price on the D3400
