help needed on tuneing mids and highs
99blazer
If you have a 80prs coming it should solve all your problems. I would keep the hpf set there for now. When is your HU making popping sounds?
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
all the time it just recently started. Its 3 years old and I bought it used so it had a good life so Im movin on to the 80prs
08 Ford F150
try turning the HPF knob down. 6.5" mids shouldn't be high passed over 100hz imo.
that's what soundqubed recommended
and did you try that?
edit: "gain only half way" means absolutely nothing. gain half way could mean you're sending straight up square waves to the speakers. headunit preout voltage determines gain amount.
how are you making sure the amp isnt clipping?
this^
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
well nothing but the gain knob that comes with the clipping indicator which I know its not accurate. but its not loud at all with it at half gain
08 Ford F150
  • Who's Online   0 Members, 0 Anonymous, 971 Guests (See full list)
