Joshex Posted August 8, 2013 Report Posted August 8, 2013 What size fuse(s) are you running for the power wire? 95 Acura Integra - 5-speedNFG Pioneer FH-X700BT(2) Rockford Fosgate 12" P3AQ1200dRockford Fosgate P1652-S 6.5" components Rockford Fosgate P1572 5x7"Rockford Fosgate R400.4 95 Integra Build Here93 EJ2 Build Here
SteadyMobbin Posted August 8, 2013 Author Report Posted August 8, 2013 Go-n-Def I've checked the polarity by following wires and using a AAA battery but I'm going to use GoldenEye's advice to play a sub sonic tone to finally verify they are firing in phase. Joshex- I have a 100 amp ANL fuse under the hood on my 4ga, and at the distribution block there are 50 amp AGU fuses for each run of 8ga.
__d_a_v_i_d__ Posted August 8, 2013 Report Posted August 8, 2013 I would seriously use a single monoblock for both subs instead of 2- 2channel amps ..... Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
BboyTaktix Posted August 9, 2013 Report Posted August 9, 2013 I would seriously use a single monoblock for both subs instead of 2- 2channel amps ..... damn that is very true I didn't even notice that. I bet getting a single mono class D amp powerful enough to drive both subs would help, plus higher amp efficiency. 2018 Golf R - Stealth SQ system build - C508GTI front (active), 2x Pioneer Z10LS4, Zapco DSPZ8, Clarion DPX11551 (Mono amp), Pioneer GM-D8604 (front stage amp), Pioneer GM-A3702 (rear fill amp) SOLD! 2011 Subaru STI - 'modest' passive sq system - JBL p660c component (front) JBL P662 (rear) JBL W10GTI (sealed enclosure) 4ch JBL GO1004 (150RMSx4), Clarion DPX11551 mono amp (+-1200RMS@3ohms)
SteadyMobbin Posted August 10, 2013 Author Report Posted August 10, 2013 It turns out the subs were out of phase, everything was wired correctly so I think it was due to having separate amps. It's louder now and hitting hard but I'm not convinced the two subs are completely in sync. Definitely +1 for a mono amp Thanks for the help, much appreciated.
goldeneye4564 Posted August 10, 2013 Report Posted August 10, 2013 It turns out the subs were out of phase, everything was wired correctly so I think it was due to having separate amps. It's louder now and hitting hard but I'm not convinced the two subs are completely in sync. Definitely +1 for a mono amp Thanks for the help, much appreciated. Glad to see you figured it out. Did you play a low tone? Or could you just tell they were out of phase by eye? I RREEALLY ANGRY WIT U PHOTOBUCKET. HAD TO USE DROPBOX NOW HOLYYYYYY. Wanna ride bikes? Quote On 9/16/2017 at 3:28 AM, Jake Pace said: Oh i know how a 12v system works I did take 3 years of electronics in High school hands on and some in college and also worked on cars in college an always got A's to B's in each class. But oh well enough dealing with ppl who have probably not even lived as long as ive been into electronics! On 7/8/2013 at 4:01 AM, Banshee421 said: Do horns get low
SteadyMobbin Posted August 11, 2013 Author Report Posted August 11, 2013 GoldenEye- I had to play a 4hz tone before I could tell, thanks for the solution.
