Added second sub and amp, no louder
First post, but been following SMD Facebook and YouTube for a bit. Please correct me if I posted in the wrong area...
I just added a second amp and sub woofer that mirrors my original install exactly, but there is no perceivable difference in volume and the lowest bass notes are weaker. If I unplug either of the subs my overall volume stays the same and the lone sub seems to perform like it should. I am wondering if I am at some limitation from the vehicle's acoustics, or if the addition of the second amp is using all of my available power from the battery.
Original set up was a Polk 15 inch MM1540 4 ohm in a 1.5 cube sealed box (per spec) powered by a PPI 600.2 bridged at 4ohms clamp tested at about 480 watts, hooked up with OFC 8 gauge power wire.
New setup is 2 Polk MM1540's, both in separate 1.5 cube sealed boxes, both have their own PPI 600.2 bridged to 4ohms, 4 gauge ofc power wire split with D. block into 8ga. Ground is 8ga leaving amps into 4 ga with one ground point. RCA signal comes from Kenwood HU into first amp, and then output into second amp. Both subs are in phase with each other also.
I drive a Saturn Vue, and both subs face the rear with about 8-10 inches of space between them and the rear hatch. PPI amps are small and sit in cubbies under rear passengers.
Any help to get me louder is greatly appreciated.
do you have a spare battery or have you done the big 3 upgrade to your electrical system? do you also have a 4-channel amp pulling juice? If you are maxing out and pulling over 1000wRMS total then you are probably being limited by your car's electrical. Not sure what size your stock alternator is either. I don't see cancellation being an issue since they are both facing the rear of the trunk....
2018 Golf R - Stealth SQ system build - C508GTI front (active), 2x Pioneer Z10LS4, Zapco DSPZ8, Clarion DPX11551 (Mono amp), Pioneer GM-D8604 (front stage amp), Pioneer GM-A3702 (rear fill amp)
SOLD! 2011 Subaru STI - 'modest' passive sq system - JBL p660c component (front) JBL P662 (rear) JBL W10GTI (sealed enclosure) 4ch JBL GO1004 (150RMSx4), Clarion DPX11551 mono amp (+-1200RMS@3ohms)
I don't have a 4 channel amp hooked up, or any other accessories. Factory alternator is ~ 130 amps could be 120, and I only have a newer stock rated single battery under the hood.
I've added 2ga ground from the battery to the chassis, and from the battery to the engine. I've been hesitant to finish the Big 3 because my alternator positive wire runs into the vehicle wiring harness and then into the large fuse box under-hood before connecting to battery. I suppose I'm just scared to run the wire directly to the battery because the manufacture didn't do so and this is my daily driver.
upgrading that wire to ensure you can supply the amps with enough power should definitely help.
Firm believer in letting my cars do my talking!
You can't rush quality, it doesn't happen overnight. Quality takes time and dedication, but the end results more than pay for it.
"Black Pearl" Build Thread
http://www.stevemeadedesigns.com/board/topic/67183-1985-buick-regal-limited-build-log/page-1
Doubling power AND cone area should net you +6dB theoretically.
That should definitely be perceivable.
How's your voltage drop at the input to the amps?
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Keep the stock wire from your alt to your battery and just add the 2gague from the alt to the battery. Your not taking away you just adding
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
I believe the Saturn Vue has a 105 amp alternator. Most cars use around 40-50 amps to run the car and its accessory's. That leaves you around 60 amps, roughly 600 watts worth of alternator charging. If your clamp results are correct your around 400 watts over what your alternator can supply. I would guess its not louder due to the amps are starving from low voltage.
im assuming you have both amps gain matched already..
you could make a box for both subs...
... good, now that you want to make a new box, make it ported! and add another battery back there!
:Jim:
fisigggg.JPEG?raw=1 Crossfire_Car_Audio2_265_zpsd219cf51.PNG ablogo_zps4c550ed1.PNG?raw=1 download%204_zpsecsgajxi.JPG?raw=1 Audison-Logo_zps3f7b2a7f.JPG?raw=1 sundown_bg2_zps1d0951fc.JPG?raw=1 orionsmalllogosig_zpsf8d08612.PNG?raw=1 KaptionLogo_zps06c2a555.JPG?raw=1
I RREEALLY ANGRY WIT U PHOTOBUCKET. HAD TO USE DROPBOX NOW HOLYYYYYY.
Wanna ride bikes?
Quote
On 9/16/2017 at 3:28 AM, Jake Pace said:
Oh i know how a 12v system works I did take 3 years of electronics in High school hands on and some in college and also worked on cars in college an always got A's to B's in each class.
But oh well enough dealing with ppl who have probably not even lived as long as ive been into electronics!
On 7/8/2013 at 4:01 AM, Banshee421 said:
Do horns get low
Yeah that wire will ensure you have sufficent power going to the amps. Are you running them off if a d block? Also welcome to the forum and its great to see another Saturn owner in here!
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Not enough power to say it's an electrical problem.
Box problem.
You may have a cancellation issue.
Try to move the boxes around. Don't face them. They are very small for such big subs, but if you fire them both elsewhere, you can hear changes.
Be sure to have them in the SAME direction.
Good luck
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
  • Who's Online   0 Members, 0 Anonymous, 483 Guests (See full list)
