g2shuck Posted August 14, 2013 Report Posted August 14, 2013 Hey guys I am looking to put a small system in my wifes 2000 camry. The car has a kenwood excelon headunit and polk components front and rear. I have a 500 watt rms at 2 ohm kicker zx500.1 amp to use. I know not the best but got it for $25. I am thinking about doing a RE SEX12D4 wired to 2 ohms at 500 watts in 2 cubes at 35hz. Will this sub and box combo work well with this amp? Also will it make pretty decent output? My lst system was a audioue sdc2.5 15 in 2 cubes at 32hz on 1000 watts rms. How will it compare to that as far as sq and spl? I know it wont be as loud but wlll it even be close? 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
bassrace Posted August 14, 2013 Report Posted August 14, 2013 What was the last system in? The same car? That's less woofer displacement and half the power. I don't know much about those re's but given the statements I'd say it won't be as loud if that's what you're looking for. There no definite answer to be honest though you'll just have to try and see. 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
g2shuck Posted August 14, 2013 Author Report Posted August 14, 2013 last system was in back seat of a mustang convertible. I am also thinking of an audioque sdc2.5 12 in 2 cubes tuned to 35hz. 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
jarrius Posted August 15, 2013 Report Posted August 15, 2013 I would stick with the audioque/soundqubed I have heard the re sex and it was ok but I like my soundqubed better 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
bcbrassard Posted August 17, 2013 Report Posted August 17, 2013 My son had a 95 axle and I put. An all infinite system in it but the subs. They were RF P2 12s in a RF box. On a 600 watt amp. Mids & highs were a 4 channel infinity amp. System sounded good. First build in a long time, have built way better since. Bass was loud but not as loud as my T1D212 on 1100. Watts.
john253a Posted August 17, 2013 Report Posted August 17, 2013 Cone is king on low power Is you can fit a single 15 ported idd do that If you want a single 12 http://www.emfcaraudio.com/sundown-audio-sa12-dual-4/ Not much more then the re but quality more then make up the price differance Even the e series and sd are very nice subs http://www.emfcaraudio.com/subwoofers/
