10 cube box with single 6inch aero port
Pauly1987
Yeah, you'd want at least 3 6' aeros then, which is expensive, I say go slot port, even if you have to drop the box down to 9 cubes, which should be fine for those 15's.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
I would make them all identical. I'm assuming that the port you ordered has flares on both ends of it. That will make that port different then the others. IMO either Go 4 PVC pipes or a single 12" aeroport.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
im guessing the box is 10 cubes gross. so use 4x 6" ports at 27.5" long for a tuning of about 33hz and a net volume of about 7.6 cubes after sub and port displacement. also i would add some bracing and a double baffle for the subs. the bracing might rise you tuning a little but you wont be able to tell.
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
You tune to net volume not the gross.
Guys no help?
4 6inch PVC at what length to get me 33hrz?
Or one 12pvc at what length to get me 33hrz?
I would love to build a new box but can't fund another $120 in material, the wify would kill me!
what are the dimensions of your current box?
  • Who's Online   0 Members, 0 Anonymous, 539 Guests (See full list)
