High-pitch Wine when step on gas peddle problem please help
Hey guys I need help bad.. I have just started to hear distortion or more like a high pitch noise that is constant as long as my system is on. While I step on the gas it gets slightly louder and more high pitch and sometimes sounds static as well.
Got any ideas of where I could start? Any questions please do ask thanks so much.
my system 2013:
single din deck
3 four channel amps
12 interior components with 12 tweeters
1 mono sub amp
3 subs
5 farad cap
2 awg main power and ground to distros out to 4awg to all amps.
Ground loop most likely
1:How are you grounding all four of those amps?
2:Are you using a distribution block?
3: Is it a good ground sanded to the metal?
4: Are you splitting the RCAs to run all those amps?
5: are rca's ran on opposite side of power wires?
6: are you using one remote turn on from the deck and splicing into 4?
7: is your head unit a pioneer? Maybe the pice fuse.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
does it have the whine while car is in "accessory" on the ignition???
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
1:How are you grounding all four of those amps? - Via distro and then to car
2:Are you using a distribution block? yes 2
3: Is it a good ground sanded to the metal? Yes because the system has been fine for about 8 months
4: Are you splitting the RCAs to run all those amps? yes 2 amps I believe
5: are rca's ran on opposite side of power wires? with this many amps it was difficult so some of them are crossed but like I said it wasnt this bad before for at least 8 months
6: are you using one remote turn on from the deck and splicing into 4? Im not splicing it but I added to it to support and link them all together. Like I spliced it in the middle and then added three to the one so hmm that could be a problem but im not sure to what.
7: is your head unit a pioneer? Maybe the pice fuse.it is a pioneer yes. its a 350 dollar pioneer that I bought about 1 years ago or 10 months ago.
Alternator noise, move your RCA's. I had the same problem.
Edit: move them away from your power cables. -- hmm ok but i didnt have it this bad before.. thanks though :)
yes it does
Didn't read bassrace's post ^^
but for 6. You could blow A fuse in your deck if you wire anymore remote wires.
really so what do I do to hook up more amps or mine effectively?
  • Who's Online   1 Member, 0 Anonymous, 833 Guests (See full list)
