djscrappydee Posted August 22, 2013 Report Posted August 22, 2013 Alright I have a S4 I charge it too 100% and take it off when I go to sleep. I dont use it in the morning and by 3rd period at school its already down to 70% of just being in my pocket. Is this normal? (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
rocking.that.eclipse Posted August 22, 2013 Report Posted August 22, 2013 Yes that is normal. I would close out programs once you unplug the phone from the charger and turn your brightness down while you aren't using it. Mine will last me 24 hours if im not on it all day
Baydestrian Posted September 1, 2013 Report Posted September 1, 2013 Somewhat....hold the Home button (physical button on the front of the phone below the screen), click the Graph icon to the left then click on Active Applications. Make sure nothing is running in the background. You can also click Setup, Battery and view what programs are draining your battery and what not. Never use Auto-Brightness. My S3 is at 12hrs 12min on the battery and I'm at 63% with moderate usage. Shouldn't need to charge it for at least another 12hrs 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
Guest Posted September 1, 2013 Report Posted September 1, 2013 if you have your accounts syncing all the time, that can drain it. the screen is usually the biggest battery drainer. if there is no signal, the phone wastes tons of battery constantly trying to find a signal.
Guest Posted September 1, 2013 Report Posted September 1, 2013 Also turn off things you aren't using, wifi, bluetooth, etc.
Baydestrian Posted September 10, 2013 Report Posted September 10, 2013 Oh yeah, like mentioned thats the biggest thing, TURN OFF DATA! It's even easier now that its built into the drop down menu....back on Gingerbread I had to DL a little app for it. Turn off data when not using your phone, you will save a ton of battery that way. 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
djscrappydee Posted September 11, 2013 Author Report Posted September 11, 2013 Thanks for the tips guys! My batterys been lasting longer (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
djscrappydee Posted September 29, 2013 Author Report Posted September 29, 2013 so today I dropped my phone. cant even tell I did it but now every time I go to my camera it says "warning camera failed". but when I go to like facebook or snapchat to take a picture the back camera works but the front camera don't. am I just fucked or is there fixing this? (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
corey0928 Posted September 29, 2013 Report Posted September 29, 2013 Take it in and see if they will replace it under warranty lol
