Ohm load help!
amps need to be off, and it looks like in the vid that the DMM probes are not in the right spots. red probe goes to the pos (+) terminal, and the black probe goes to the neg(-) terminal.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
All 4 squares on each circle represent the quad coils on each sub. Each one is at 1 ohm. Now, the blue lines between each of them represent wiring them up to 2 ohms a piece, giving you 8 total 2 ohm voice coils if you will. Now, you wire those down to 1 ohm again with the yellow lines, essentially wiring each individual sub to 1 ohm. The final result of these connections are in the green box at the bottom. Now you wire these back up to a 2 ohm load by connection the pos and neg from 2 subs and pos and neg from the other 2 subs. Now you have 2 2 ohm voice coils essentially. Wire the remaining positives and negatives together back down to 1 ohm.
Got it, now gimme time to write an explanation
:roflmao: wtf is that.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Let me know if this sounds right to everybody
Hey hey hey, I just woke up cut me some slack :P
all good loved it.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
You know I have 4 subs right?
I do not want to risk anything with this amp at .5
I appreciate all your quick responses and trying to help me through this!
Yes. I do.
Are you not running two subs per amp?
Hey all thanks for the responses. I'm busy at work for a couple more hours and will respond to everyone when I'm back home!
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Got it. Except I was connecting it right.
PERFECT!!!! Thank you so much. See I already have everything wired up till the green box part. That's what my 4 sets of bolt terminals are. Thankyou so much.
Yes. I do.
I WAS running 2 subs per amp. I am NOW running 4 subs 1 mono
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Would this way change anything with the impedance? My ocd is going crazy by not using all the inputs on the amp:P
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
  • Who's Online   0 Members, 0 Anonymous, 1003 Guests (See full list)
