Ohm load help!
The inputs are internally linked inside the amp, they are just there so you have more terminals to use when you've got lots of wires to lots of coils.
You have 4 quad 1 ohm coil subs, correct?
Wire each sub to .25 ohms (all coils in parallel), then connect the subs in series to each other. Your BC5500 will see 1 ohm.
If you test a coil and see a negative impedance it is because you have the probes or wires on the sub backwards.
Hammerdown... 1%
I know they are linked. Just being ocd like i said. So since they are linked, theb i should be able to have them separate right? Just did a mockup of his diagram and it works beautifully! Thanks everyone!!
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Its all good man I really appreciate you trying to help a lot!
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Also, before you fire anything up be sure to take a decent multimeter to it and check out the resistance. I believe you should be able to do it the way I did it up or the way you did it up with the 2 pos and 2 neg coming out. Won't hurt to check after you make the connections though :)
I checked man, got 0.9 woo!!! Thankyou
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
  • Who's Online   1 Member, 0 Anonymous, 1555 Guests (See full list)
