'05 Ford Escape Limited *SKAR AUDIO BUILD*
Anyone know a place online or local in Canada by any chance to get 8" aeroports? or just 4 of the flares
Deck: Kenwood DNN990HD
Front Stage: (6) 8" Skar Audio PAX-8 Pro Audio Speakers - 3 in each front door (4) 1" Skar Audio VX1-ST Bullet Tweeters - 2 in each front door
Subs: (4) 15" Skar Audio VVX-15v2 Dual 4s wired at 1 ohm
Sub Amps: (2) Skar Audio SK-2500.1
Mids/Highs Amp: (2) Skar Audio LP-80.4 - powering mids/tweeters
Wire: (4) runs of 1/0 cable front to back, T SPEC V12 RCA
Batteries: (5) group 34 batteries - 1 up front, 4 in back
C-pillar flat wall
Buid Log: http://www.stevemeadedesigns.com/board/topic/174250-05-ford-escape-limited-skar-audio-build/
I'm in the states but there is a guy on caco who makes them cheap. I emailed him about some I'll see if I can find his email. Also I'm tuned in man!
Edit: the email is [email protected]
Thanks buddy! We managed to grab a couple local, hopefully box build will be up this weekend.... today we decided to start mocking things up temporally as I'm just hurting to hear these things!
So we started making room for one of the 2 back battery's to fit in the left quater, box is going to be 12 cu/ft before port. 2 8" aeros is the plan.
1236030_10151675798893041_713926674_n_zp
1187207_10151675798538041_1410260657_n_z
1234125_10151675798938041_2016782274_n_z
C-pillar flat wall
Hey man good start i used to have an 05 that was grey limited edition 4x4 great vehicle wish i never would have gotten rid of it, fun as hell keep up the good work.
provided everything goes smoothly tomorrow should have the box assembled, braced, subs in, and amp wired for testing tomorrow. Just dying to hear it, lol. Decided to go bottom slot port, and subs inverted.
EVERYTHING is going to be torn out soon to be deadened, resin the box, run more wire under the carpet, etc
C-pillar flat wall
you running the 2500.1 at 0.5 ohms?
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
thanks guys. yeah the 2500.1 is ran at .5 ohm. was demo'ing all day saturday subs or amp didn't even get warm. Voltage was fairly steady for what it was too. Only the front battery is wired up for now, 1 run of 0 for power and 1 run of ground from the front battery to the 2500.1. back battery will be wired up soon as I get some extra time.
TO DO STILL:
wire up back battery
deaden EVERYTHING
add extra bracing to the box
PL/resin in the box
rhino liner the box
thats all I can think of at the moment. lol
So we threw the box together its about 10 cubes at 29hz before port/subs. Probably should of done it differently but i wanted to try this and see how it goes/sounded. So heres how that all went..........
644011_10151687582158041_312593397_n_zps
we used sky high audio cables 8 gauge for speaker wire. AWESOME quality stuff if your in the market for some wire check these guys out!
1240385_10151687584153041_738940786_n_zp
mounted the 2500.1 on the back seat, threw it all in and called it a day! Left the shop at 12am... few hours of sleep and off to a show the next morning managed to do a 148 on the termlab @ 46hz ... Aiming for the 50s after all my to-do things are complete.
558600_10151687584598041_411899027_n_zps
been running it all inverted given the size of the box, port back for now. I'm surprised the number i achieved given this box has got to be choking these subs out.
1234693_10151687584348041_2081671917_n_z
C-pillar flat wall
