'05 Ford Escape Limited *SKAR AUDIO BUILD*
You should plasti dip them wheels black
Thinking about powder coating them. Not a fan of plasti dip
Deck: Kenwood DNN990HD
Front Stage: (6) 8" Skar Audio PAX-8 Pro Audio Speakers - 3 in each front door (4) 1" Skar Audio VX1-ST Bullet Tweeters - 2 in each front door
Subs: (4) 15" Skar Audio VVX-15v2 Dual 4s wired at 1 ohm
Sub Amps: (2) Skar Audio SK-2500.1
Mids/Highs Amp: (2) Skar Audio LP-80.4 - powering mids/tweeters
Wire: (4) runs of 1/0 cable front to back, T SPEC V12 RCA
Batteries: (5) group 34 batteries - 1 up front, 4 in back
C-pillar flat wall
Buid Log: http://www.stevemeadedesigns.com/board/topic/174250-05-ford-escape-limited-skar-audio-build/
Had some time the other day so we decided to take out the box and have the port face forward since it was being obstructed facing the back as well has wire up the back battery. Sounds alot cleaner and louder now after both of those, hopefully have some meter time in before Saturdays show.
1238828_10151695914253041_36680074_n_zps
547034_10151695914083041_1587114017_n_zp
1231615_10151695914798041_1119379678_n_z
558062_10151695914908041_1280717202_n_zp
13002_10151695914153041_890718372_n_zpsd
C-pillar flat wall
If u swap to make the port play backwards it probably increase...
have you tried that?
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
it did a 148 @ 46hz that way
C-pillar flat wall
with the port forward now gained a bit, its getting there. We deadened the liftgate after this number but didnt have time to test again to see if any gains. Probably won't see any major increases until we resin.
Thinking of doing a different box idea now, will have info on that soon
1234384_10151704398253041_789460147_n_zp
C-pillar flat wall
Maybe try port up? I've seen an explorer that had better numbers sub forward port up than he did with port back. Just a thought. GL with the 150! Don't see many Escapes on here :)
2006 Ford Escape
Head Unit: Kenwood KDC 352
Subs: (3) 15" DC XL 15s with PSI recones, 1.4 ohm coils
Sub amp: DD Audio M4 (Black Version)
Door Speakers: (2) Crossfire 10s, (2) Hertz Coax.
Mid/highs amp: Rockford Fosgate P500-4
Electrical:
XS D3400 under the hood
(3) XS XP3000s in the back
2 runs of KnuKonceptz OFC 0 Gauge ran to the back (1 pos, 1 neg)
Excessive Amperage 300 amp alt (FINALLY!)
Not enough hours in a day.... sorry for not having much updates lately on this guys. Got around to doing the voltmeter today, wired at the amp. Also got ahold of a couple dual inputs for the amp whenever I've got more time to run some more wire. Hopefully start on the doors soon. Having more bass then vocals is killing me.
993414_10151721145338041_84865960_n_zps0
1378897_10151721145273041_1761938545_n_z
C-pillar flat wall
  • 4 weeks later...
haven't had alot of time to really do much with this build, been busy with the shop with remote starter season and what not. But I did get around to doing the hid's and tint. Hopefully start on the doors soon...
8000k headlights and 12000k fogs
1186105_10151761150503041_624522693_n_zp
18% up front and 5% in the rear
1375817_10151761150443041_1336482852_n_z
C-pillar flat wall
