I like option 2. reason one is that I have not seen or enough about the DB drive components. Reason two is that I find even with the stock tweeter location has to much reflection off the window so I am no sure about tweets in the pillars.
I like the door pods in this Z. https://www.facebook.com/photo.php?fbid=4251553140863&set=pcb.170896776398120&type=1&theater scroll through the pics.
Decided with option 2. I think best quality and ease of install. I need help though on amp:
http://www.sonicelectronix.com/item_69444_Orion-CO2000.4.html
http://www.sonicelectronix.com/item_67884_MB-Quart-RA1000.4.html
I'm leaning towards the Orion because it has a higher 4ohm rating. I've never worked with orion though. I'm open to suggestions.
Looking at the specs they are pretty much the same. I like the way the Orion looks more. The Orion does also claim a higher 4ohm rating. the only other deciding factor is do you want the wiring on the front or the side?
  • Who's Online   1 Member, 0 Anonymous, 898 Guests (See full list)
