This weeks Amp Test Tuesday.... the classic, BEAST Rockford Fosgate T4000.1bd. I used to run these from about 2005 up to about 2007, 08ish (iirc). I have been reluctant to do this test because i KNOW my battery bank is really only SOLID up to about 2000-2500 watts. Right around that area, the amplifiers really start to pull on the battery bank hard. The AD-1 and the amp being tested FULLY rely on the power which you present to the amp during testing. As you know i have only 3 D1400's on a 10a Intellicharger. In other words, you can't always blame an amp if it doesn't make its power. You gotta power the power to get the power. That being said, check out the video tomorrow and see how it did, with the power i had at hand.
I got an SMD hat and some SMD D'Amore Engineering Stickers for the person who guesses the closest to the actual number i am looking for :)
The amp is rated 4000x1 @ 1ohm at 14.5v.
Certified Mode (test stops at 1% distortion) - x,xxx watts
Un-Certified Mode (test stops at clipping) - x,xxx watts
Dynamic Burst RMS (test stops at clipping) - x,xxx watts
add up all three numbers for one final BIG number! Closest gets the hat and stickers!
Results tomorrow @ http://www.youtube.com/meade916
how do i collect my cap and stickers?
dang so much for those batts not being able to hang! 3.8k no alt what so ever. jesus
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
I have the cure for the lack of an alternator on your test bench. Use something like a shop fan motor, or similar device that can create steady rpm, to belt feed an alternator mounted on a tension pulley. Then wire as necessary and viola, alternator powered battery bank to simulate a running vehicle. Of course you could do some math and get the right pulley sizes, or a variable speed motor, that way you could control the rpm for all the haters that love to try to find some way you cheat in every video.
  • Who's Online   1 Member, 0 Anonymous, 740 Guests (See full list)
