dashboard help
Since I am off work this entire week and the weekend I wanted to see if I can get a kick start on building my center part of my dash where the stock radio and hvac controls all are. I have a 10" touchscreen I am going to mount in it along with 2 SMD vu-din's. Currently I have the wires all ran so I can move the HVAC controls to the glovebox and then I will take the radio out for good and just use a carputer for my system.
My question is how do you guys mod your dash and still get it to snap back into place? My center part of the dash has little metal retaining clips all up the sides of it that snap it into the dash and then it has 2 screws at the bottom to secure it in. Should I just mount the touchscreen and the vu-dins on top of the dash bezel or how do I go about doing this? I don't want it to be ugly and stick out a ton and I don't want to see any screws sticking out and I figured that if I were to take the dash bezel and mod it that it would probably lose some of the retaining clips and I didn't want that.
bump, I know its been done before with dash's like Meades and plenty others out there.
Everyone is different but on the few dashes we did we just built off the stock dash. We cut out a lot of parts but left the clip areas alone, made our own frame around then glass. They never really...stuck out too far.
I'm going to completely redo my entire dash to cut almost everything out and I may not even be able to keep the stock dash at all. I'll be reading up and send you any information that will be useful
okay cool. thanks man. I was thinking to build it out too because it wouldn't be that bad but it would be close to where the shift is in the center.
Pics? Chevy were the only think we worked the dashes on, not purposefully...now that I think about it it just worked out that way, lol. Where I cut out I was able to make our frame so that it looked almost flush with the rest of everything else. Not too much stuck out. And on one it did but that's because it lined up with a glassed center console
its not mine but its the same style but now its an aftermarket headunit in my truck. Here is what it looks like: http://images.gtcarlot.com/pictures/50287664.jpg I believe I measured 1.25" from the dash bezel to the shifter or maybe it was 2" idr but it would be close to it if I were to keep it out even with the lcd panel. I was thinking maybe keep the lcd panel out and then somehow make it go in under the lcd where the vu-din's are going because the vu-dins have like no depth to them.
  • Who's Online   1 Member, 0 Anonymous, 343 Guests (See full list)
