Good "high/mid" bass subs?
N9neMillahhh
I'm getting a sundown Zv4 10 for lows, and i know it's gonna slaughter the lows, and my speakers wont be able to handle the mid/high bass that i'm sacrificing, so im lookin at a pair of 8s that can play the mid to higher bass ranges, probably about 50-60Hz up to 100 or so Hz, since my cabin speakers can't play those loud enough, so i need midbass. Bass like in "Bang Out" by Tech N9ne, higher bass and mid bass a little lower, up to where my speakers can kinda take it from where the subs leave off, so any suggestions would help, a couple 8s that are good in mid-high bass. Thanks in advance!
02 Lexus IS300 (2JZ FTW)
Mids/Highs: JL Audio C5 6.5s all around
Mids/Highs Amp: JL Audio HD 600/4
Subs: four SA-8v2s in 3.8cubes @ 32hz
Sub Amps: SAZ3k
Battery: Huge Interstate Batteries relocated to trunk
About 80ft. of 1/0 OFC....
Head Unit: Pioneer 4200NEX
What speakers do you have for your frontstage? A pair of good 6.5 components should be able to keep up with a single 10" We could recommend an 8" midbass but I would let them play from 60-250hz. Where do you want to place them? Budget, depth, power available?
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
Setup in sealed many if not most 8" will do a good job in the midbass region. Something from DD are a likely candidates.
I wouldn't buy anything before playing with the 10" first though.
Well my front stage is a set of AQ components with AQ pro 6.5s instead of the ones that came with the component set. And my doors have a speaker compartment but it's just a plastic "shield that covers the top of the speaker to protect from water, otherwise there is no enclosure. The speaker is playing into my door, not the panel though. So I got some baffles to try and help and they don't really do anything...so I need a mid bass solution. That 60-250Hz sounds good to me, and I'm currently running an MB Quart 2-chan to a pair of Rockford power 3-way 6x9s in the back in some 6x9 boxes and you know my fronts. Each speaker is getting about 100 watts rated, but I know they probably aren't really getting that.
Sub Amps: SAZ3k
Budget, I don't wanna spend a whole lot cause I'm getting a 4-channel soon, and the 4-chan will send 60w to each speaker, and I'll probably run the new speakers off the same channels as my components. So 60w to the pair of the mid bass speakers. I'd say 100 max for budget. Depth not sure. Maybe like 6"?
Sub Amps: SAZ3k
DD6.5?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Also the 10 is meant for lows, so I wont be playin it high at all, like 20-50Hz. And location, not sure. Rear deck in a box between my 6x9 boxes? Or build one big long box for the 6x9s and the mid bass speakers I decide on. Not sure where yet. Trunk wouldn't be a good place would it? Lol
Sub Amps: SAZ3k
Which DD? The SW or the W?
Nevermind looked it up...I hope they mean 170 for a pair of em...even then that's pushin my wallet.
Sub Amps: SAZ3k
I really don't know if that is for a pair, but dd isn't cheap
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
That's fo sho...
Sub Amps: SAZ3k
  • Who's Online   0 Members, 0 Anonymous, 428 Guests (See full list)
