question pls help
vw passat
But that's port area per cubic foot. Don't worry about that ;)
I've had boxes with 7sqin per cubic foot. Extremely musical, got loud, played from 24hz up to 60hz fairly flat too. I had a home theater box with 19sqin per cubic foot. Same deal. Very musical. I've had boxes in the middle with 14 per cubic foot. Same idea. In all of those boxes, I never paid attention to the port area per cubic foot as much as I did my total port area
I don't know how your doing your math, but area is length times width.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
If you go that over 20 sq inches, then you are going to have to make the port longer to compensate.
I believe once he goes below 2" wide he will have problems just from how small the width is. Just leave and go build it.
If I'm remembering correctly the box for one of my single Zcons on a 2100 had a port area of 13x2.5. Didn't have any port noise, played to 26hz and was just barely wider than OPs. I'd think something with 1/3 the Xmax on <1/2 power tuned to same frequency would produce less port noise with same-ish specs right? Only way to find out is to build it though!
  • Who's Online   0 Members, 0 Anonymous, 428 Guests (See full list)
