Weird low voltage. Only 1000w RMS system! Help?
Alright guys i found this. Its a 140amp HO alternator for my car. Do you think its worth it? Buying this will delay my build quite a bit.
http://www.maniacelectricmotors.com/11058hiamp.html
Theres also a 160amp version for $250 with core exchange.
http://www.maniacelectricmotors.com/160amphioual1.html
And here's just a stock remanufactured 75amp.
http://www.maniacelectricmotors.com/13820.html
Build in progress:
-Pioneer Premiere DEH-P49OIB
_Kenwood Excelon KFCX173 6.75"
-Kenwood KFC-1094PS 4"
-DB Link 4AWG
-Soundstream DTR1.900D
-Obsidian Audio v2 12" D2 @1ohm
-L-Port, 2.5cubes @32hz
CHECK ME OUT ON YOUTUBE
When upgrading you're alt stock wiring will really get hot if the draw is high say you're pulling 50 amps through stock wire. (Usually 10 gauge or 8 gauge)
At 10 gauge (25A/Ft) thats pretty much maxing out how much it can handle.
At 8 gauge (35A/ 15Ft) you're a little safer.
This is using OFC not CCA.
Upgrading your alternator power wire and the ground strap from the block to the chassis should be fine. Under a load the voltage will drop slightly, no they aren't strictly regulated, but they are not way out say 18 volts max output from the alt to the battery.
Pay careful attention to grounds make sure they are big enough to allow the electrons to flow properly to the positive connection (without shorting)
Here's a 150A H/O Alt:
http://www.ebay.com/itm/HIGH-OUTPUT-ALTERNATOR-SUBARU-FORESTER-IMPREZA-SAAB-9-2X-2-0L-2-2L-2-5L-150AMP-/281028171927?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1999%7CMake%3ASubaru%7CModel%3AImpreza&hash=item416e959897&vxp=mtr
With those alts you would be fine. The question is, how long did you want to drive the car and do you think you´r heart want an upgrade later.
If it so go with the stronger one.
And do the BIG 3 in O/1 gauge, smaller there arent the big 3, lol.
"in the abundance of water, the fool is thirsty" Bob Marley
Guest DC Power Kyle
Idle output will suffer on those alternators.. you won't be happy with them.
Well then what should I do? I cant really afford more than $250 on an Alternator right now.
Build in progress:
-DB Link 4AWG
Get some 1/0 and try the big 3 if that doesn't work go to the next thing, test your battery with and without your car running, the charging system should be 13.8v at idle on average. It is possible that one of the sense wires were pinched or isn't properly connected. There is something off about this, on my other vehicle (no longer runs) only had a 90 amp alt, never had issues but it went out 2 times. But the whole system would stay at 14v running idle even with the stereo and amp on (when I first started out my system was only 200 watts). Did you check the cables like I suggested?
That's normal. Idle output on those alts SUCKS. I know that one from experience. I can be sitting at a stoplight and if I turn on my fogs and headlights at the same time it will drain down to 12.4v lol
A good alt will be more than that. Try double, plus a bit more.
Your best bet would be to avoid going full tilt at idle. Rev your car or drive around if you want to bump. Turn off accessories like headlights, vents and air conditioning, etc if you are stopped for more than a little bit
was just gonna say he wasn't gonna get all those amps
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
  • Who's Online   1 Member, 0 Anonymous, 1835 Guests (See full list)
