N()()b who needs box help. *surprise surprise*
Hey everyone,
I'm new to the forum. I am doing a simple install in a 2000 Honda accord coupe. I have one of the older model jbl gto 1200 watt mono block amps with a 4ga run from the batt. With no light dimming. And I have an inexpensive Sony head unit running through an alpine ktp445u amp to my highs and mids which are memphis mclass 6.5s in front & 6x9in the back. My sub is a single sundown sa-12 and is seeing roughly 800 watts from that amp. But all that to get to the heart of the issue. I need a box. Or blue prints at least. I want the best box for a mixture of sound quality first but also some spl. Any help is greatly appreciated.
Life's a trip. . . Don't fall.
Post up what sort of space you have. height, width, and depth
You may see more help if you post in the subwoofers/enclosures section though
Welcome to SMD :)
Sure, height:15" or less
Width:30" or less.
Depth: variable. Up to 25"
I've read the SA-12 performs best with about 2-2.5 cu. ft tuned to about 35hz but I have never build a box before, so I definitely need some guidance. Thanks.
What sort of music do you listen to? Lots of low-note chopped and screwed stuff? Rock? Hip hop? Dubstep?
You've got about 5 cubes to work with there so you can pretty much do what you want with that sub. But knowing your musical preferences will help.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
A wide variety. 50% rap, or bass heavy music, other 50 percent country and rock
Edit: sorry it was showing an error message then Went nuts and posted all this. Now I know. Sorry about that
  • Who's Online   1 Member, 0 Anonymous, 610 Guests (See full list)
