SMD Folding @ Home Team
laptop i have roughly 13000 ppd and the tower i have a whopping 300 ppd. might put it on the other tower with amd fx8350 and msi raedon hd7970 i think it is. should i put it on that one? configure to run light when not in use.
That 7970 is a really good card to fold on. Try adding the client-type advanced flag for that card's slot, some people report 60k+ PPD with that card pulling advanced WU's.
I should probably edit the first post with some of the useful flags
I was off by a series. I've got the 7870. Running gpu and cpu overclock. I'd fold on laptop cuz its actually more powerful but only can do it at home while plugged in.
The 7870 is still good for about 40k on advanced WU's. The science appreciates any/all donations of computer time no matter how big or small. :)
Fold on
How can u get that? I'm only getting like 10k ppd from it. Ill check again but idk it seems really low for what they are.
Here is a quote from Stanford's page. In short, you need to successfully return 10 WU's before you start getting bonus points. My bad, I forgot to mention that since I've folded before, it didn't cross my mind.
http://folding.stanford.edu/home/faq/faq-points/
Bonus Points
The prompt completion of Work Units (WUs) is very important for the science we’re doing. In order to study the proteins we’re interested in, we need be able get the results back quickly. A faster turnaround also means that we can launch projects that are larger and more difficult than ever before. So in 2010 we introduced the Quick Return Bonus (QRB), which gives extra points to users who rapidly and reliably complete WUs. The QRB has been fairly successful in aligning points with scientific value, and we will continue to use it.
What are the qualifications for the QRB?
The bonus is applied for users who use a passkey, have successfully returned at least 10 bonus-eligible WUs, successfully return 80% or more of assigned WUs, and return the unit before its Timeout (formerly Preferred Deadline). Bonus points do not apply to partial returns.
When I hear music, I fear no danger. I am invulnerable. I see no foe. I am related to the earliest times, and to the latest.
~Henry David Thoreau
This kind of started out as a thread to gauge interest, I should make a thread with a load of FAQ's, tips, guides and more concentrated info for those that may want to join.
Hopefully I'll have time for that this weekend.
Fold on.
Yeah, I'm getting 30k ppd on 2 470 gtx's and an i5 3750 @ 4ghz
30k on total for both GPU's + CPU?
I guess I'm doing good? Any bit helps though :)
Lookin good :good:
^^^ god damn!
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
it looks like its running on both GPU's but that doesn't make sense, because two 470's are defiantly way faster than a 580.
Are you using a passkey?
anything I can do to boost the cpu on my laptop? Its completely slaughtering my gpu so y not boost it. And tower is doing way better after adding the advanced client type. Running at 58.5k ppd on it now.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Unfortunatly there are not any really useful flags that the average consumer CPU would benefit from. Just the standard advanced client type, use a passkey for QRB's, etc. The big points with this new Core 17 client are making GPU's shine more than CPU's unless you are running servers, the bigadv flag for CPU's requires atleast a 16 core system.
So is it just my gpu that sucks? I've got a quad core i7 at 8 threads doing 16-20k ppd and quadro k1000 doing 6-10k ppd. But the tower I've got amd fx 8350 8core doing 7k ppd and msi raedon 7870 doing 50k ppd. Does that all seem right?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
