wrexxy Posted September 5, 2013 Report Posted September 5, 2013 I installed the front and rear doors. My problem is that the front and rear left doors are speakers are working, but are MUCH quieter than both right doors. I have 14 awg by 2 stinger hpm twister wire, and i really had to force it through the boot to get it into the door. could i have split the wire or something? I tested everything i could think of at the crossovers, and i don't think that its a problem with signals coming from my amp (switched wires from amp but problem still persisted at the doors). not really sure how i can check the wires themselves? or the connections to the speakers? the wires were "quick disconnected" or whatever those terminals are called to the speakers. and they were a real pain to get on the speaker terminals. speakers are Image Dynamics CTX65cs and CTX65 coaxials. cars a 2013 wrx. amps a polk audio PA4000D.4 open to any ideas/suggestions
Sergeant_Skyrim Posted September 5, 2013 Report Posted September 5, 2013 Are you sure you didn't mix up some of the wires? Are the left and right sides of the car running to different channels on the amp perhaps and the gains are mismatched slightly? Build in progress
wrexxy Posted September 5, 2013 Author Report Posted September 5, 2013 i labeled the wires... but i could have screwed up the labeling, added to my list of things to do to diagnose the problem
wrexxy Posted September 5, 2013 Author Report Posted September 5, 2013 also, the left front tweeter seems to be cutting in and out. it'll sound at the same level as the front right and then i turn up the volume and then the volume decreases noticably to that of the woofer on the left side
Dan2427 Posted September 5, 2013 Report Posted September 5, 2013 I had had that with my focal speakers.. But the JL mid in the back was blow and when I turned it up it would cut out all together. Sometimes crackle and make my other speakers sound bad too. 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
ham4864 Posted September 5, 2013 Report Posted September 5, 2013 bench test the speakers to see if the problem is still there. Then report back. 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6
wrexxy Posted September 6, 2013 Author Report Posted September 6, 2013 so i pulled out my DMM and check some of the ohm readings at different places in my system. The two left speaker wires, from the amp are reading 0.4 ohms (negative and positive of one wire), when checking against ground they were ~2 ohms if i remember The two right speaker wires read ~4 ohms (negative and positive of one wire), i didn't check against ground. I checked at the crossovers: the right tweeter was surprisingly low, around ~1 ohm even though it seems to be working. the right woofer read ~ 4 ohms the left tweeter read about ~0.8 ohms the left woofer read about ~0.8 ohms as well So what blows me away is i literally just hooked the system up this morning and it sounded this way from the get go (after setting the gains with an oscope and test tones i got from this site some post about "tunes and tones") Are the speakers blown or is the wire being grounded somehow? Or is there a way i can check the actual speaker itself? I have a DMM and an o-scope
ham4864 Posted September 6, 2013 Report Posted September 6, 2013 bench test the speakers to see if the problem is still there. Then report back. Take them out of the car and connect them a external audio source(bench test) 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6
pioneerforlife Posted September 6, 2013 Report Posted September 6, 2013 there is something either blown or wired incorrectly. try pulling out the woofers and tweeters and test them outside of the car. if it reads the same outside the car, there is probably something wrong with the speakers. if it reads correctly, either something is wired wrong, or you have some split wires somewhere. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
wrexxy Posted September 6, 2013 Author Report Posted September 6, 2013 i don't really have anyway of testing the speaker out of the car. i can swap speakers (L/R) in the car and see if the problem switches sides
