ham4864 Posted September 7, 2013 Report Posted September 7, 2013 Hi SMD i am thinking about putting my amp in my spare tire well but.....I have a few ??? 1. Would you ditch the spare(donut) 2. Does the amp run hot and should you cool it with fans. Thanks 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6
Tribe Called Bass Posted September 7, 2013 Report Posted September 7, 2013 I believe this should come down to your own personal preference, if you are shit out of luck on space and loaded up with fix-a-flat and have nice tires(Shitty ones risk blowout, so fix-a-flat is worthless) then do it. I cut out my tire holder as well, I'm working on A battery bank. As for the amp, you should know if it gets hot or not. If it does, then well, get some fans!
jarrius Posted September 7, 2013 Report Posted September 7, 2013 I would not because to me it will get hot. But that's just me 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Karkov Posted September 7, 2013 Report Posted September 7, 2013 I ditch my spare in all my vehicles always. Depends on amp for heat and exactly how much you seal it back up. Personally I would add a fan no matter what though. If/when I ever have a need for one this is what I am gonna go with http://www.sonicelectronix.com/item_16879_Stinger-SGJ78.html 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
n8ball2013 Posted September 7, 2013 Report Posted September 7, 2013 Spare tire? I have roadside assistance ill make a phone call THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kenyel Dotts Posted September 7, 2013 Report Posted September 7, 2013 If this amp is properly grounded and is given the power it needs it should not get that hot with a clean signal source and the proper enclosure (woofers). But check on it every so often. If the amp gets hot put a thermal switch on it and get some fans. King dingalingIts not finished till i say so Bit@^!
n8ball2013 Posted September 7, 2013 Report Posted September 7, 2013 Its not about being properly grounded kr clean signal. Its about being enclosed THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kenyel Dotts Posted September 7, 2013 Report Posted September 7, 2013 In that case I would put a fan in with a thermal switch. With the thermal switch it would save on power because it shuts the fan off when not needed. King dingalingIts not finished till i say so Bit@^!
ham4864 Posted September 7, 2013 Author Report Posted September 7, 2013 good advise from every body. I have roadside to but they take to long. Good advice on the thermal switch. I have some thinking to do i'm not out of space. 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6
Tribe Called Bass Posted September 7, 2013 Report Posted September 7, 2013 good advise from every body. I have roadside to but they take to long. Good advice on the thermal switch. I have some thinking to do i'm not out of space. Well if you have space, I'd keep it away from the well, because idk about your car, but mine has vent holes on the bottom, so it gets pretty humid.
