2, 4 channel amps
Is it ok to split an rca from the HU to 2 different amps?
in other words,
HU/front to front channel of amp 1 and front channel of amp 2 for a set of comps and super tweeters
HU/rear to rear channel of amp 1 for a set of mid drivers
HU/sub to rear channel of amp 2 for to sub
what amps and what head unit?
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
how many inputs do you have on the back of your head unit?
1 input, no. You'll only be able to power your speakers, due to the fact that it's A stereo output, not A mono input.
2 inputs, yes. You have one stereo for speakers, one for mono. It'll display it under the R/L. You can use an adapter, one adapter in your stereo to drive your tweets/mids.
what he said
2009 bmw 5 series
Head Unit Stock
Yes, you can do exactly what you described. That's similar to what I'm doing in my truck and it works fine. Although, if one of your 4 channel amps has outputs, that would be a cleaner way to split the signal than using Y connectors. Not that Y connectors won't work, mind you, but it will be a cleaner install if you have the outputs available.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
you can do it, but you will degrade the signal. Besides that why would you want any amp that doesnt have preouts. I wouldnt own a amp that didnt have preouts. You never know when you may want expand your system.
truthsayer
It won't degrade the signal. It will lower the preamp voltage, which will be compensated for when gain is set.
The HU is a Pioneer sumtin sumtity sumtin...it has 3 sets of pre amp outs, front, rear and sub, very much resembles the 80prs.
I am purchasing another amp and instead of buying 2 new amps, I am trying to figure out a way to incorperate the one I already have into the system.
I may end up scratching the whole deal and buying another amp anyway.
Just wanted to know if one signal could be split to multiple amps.
you can do that then...
it could be split but theres no point if you want to use one amp for front and another for rear.. just put two runs of RCAs for 4channels (front rear) and one for sub stage..
u can also connect RCAs of second amp to RCAs output of first amp but you will have less control.
GL
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
  • Who's Online   0 Members, 0 Anonymous, 1530 Guests (See full list)
