Why Am I Not Getting Full Potential
Well no offense to you or anything but if the sub+ does control the voltage to the amp, I can get that 1400....
My amps are rated up to 1500 each, I just chose lower to prevent clipping....
Yeh....if you can get them to hold at that ohm you wired them to
But theres a lil thing called impedance rise that determines what your amp actually sees....depending on heat,box, and other....it can rise a good bit and never be close to the nominal load
You can get a clamp meter to get an idea of where they are at and what kinda power its actually seeing
2004 Explorer4 12" Type R500.1(.5 ohm)6cu@35hz153@ 44hz
Install and box is 90% of the score and results.
No. Car is 50%, box is 40%, and equipment is 10%.
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
Id give the edge to the box.....60 box, 30 car, 10 equip
You can have a rex and ruin it all with a bad box.......or design i should say
Or have some random 4dr Neon and great box and pull better numbers than that crx with crappy box
You can get a crappy car loud easier than you can with a bad box, or design
thread cleaned up
the talk may be been constructive, but it really didnt have much to do with anything here....start a different thread if you wanna talk about leaky boxes
What does it matter if we're bumping his thread for others to look at?
you'll are crazy, use a dmm
on a Alpine IVA-D310 CD / DVD for my friend with:
2 18" fi ssds 12cuft@32hz
hifonics 2000d
stinger1700(2)
0 gauge
200a alt
with a dmm only until sub # at 15 did i see anything near 2v
it is not clipping, call alpine, when i did, they said that like jvc, the sub # needs to be all the way to 15 for full voltage
pioneer and sony's sub number is a bass boost at a specified frequency, alpine and jvc are level/voltage adjusters
(keep in mind this is what i've been told by each companies tech dept. when i was using their headunits for a system setup. I do this everytime i have a new headunit i havent used since you'd never know)
This is how i blew my RE Audio amp, i set the sub setting too low, then to compensate set the gains to high, which sent some crappy signals to my subs till they couldnt take it, now, with my jvc kd-shx8500 sub setting @ 12 instead of 0 like i thought it should be, it sounds a lot better/cleaner and the gain went from being set at 3/4 to 1/4!!
so we have it set at
volume 22 since it sounds bad after that (62% total volume only! :angry: )
sub at 15
and MXE at cc3
hope this helps
actually that helps a ton. It confirms everything I was thinking so I definitely should get way louder soon!! Also since I will be able to lower my gains I can probably give my subs more power as well! I originally thought that was a bass boost which is why I didn't use it....
A vitrolic, megalomaniacal sadistic psychopath.
  • Who's Online   0 Members, 0 Anonymous, 1272 Guests (See full list)
