Why Am I Not Getting Full Potential
I looked at the build log, good job man. My theory is, even with the double baffle, the enclosure is not rigid enough. I would beef that sucka up if possible whether it be with all-thread, 45's, bracing, glassing, or all of them. Id take care of the air leaks where the speaker wires run through and use a bolt/teenut combo to secure the subs to the baffle. Hope I didnt come off as a hater, peace
That wont help if their almost to full already
sure it will help, it will help him not destroy his subz/amps because of clipped signal.
sometimes have all the settings correctly instead of just turned all the way up, you can get louder and Sound better doing it.
Guest Nismofreak
has to be tunning man. I did a 145 with my yellow top and my 60amp alt bassracing. My kinetic helped me. Just tunning in mine opinion
build a 2nd box and use it just for spl.
something like.....
box - 41X18TX20D
port - 39.5X2X10 across the bottom
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
Guest Nismofreak
something like.....
box - 41X18TX20D
or swappable ports. I am gonna build one with 35hz and 45hz ports
that wont help much. the tuning isnt the biggest issue. its the physical size of the box.
Guest Nismofreak
he could go to 5.5 cubs and still do it.
so basically I have too big a box for high numbers? I thought I had pretty much the lowest recommended box size already....and I had it set to a 35hz tone for 1400 watts....I'll keep that second box in mind if I get the money, and hopefully the second battery will help too! I'm not offended by anything you guys say I just want all the info I can get...
A vitrolic, megalomaniacal sadistic psychopath.
Guest Nismofreak
well with that 220amp alt. You should have enought back up but yet a second battery will help.
  • Who's Online   0 Members, 0 Anonymous, 3506 Guests (See full list)
