jmfrb1 Posted September 16, 2013 Report Posted September 16, 2013 I was wondering if any of you have tried to plastidip a box yet and how it went? Yes I know I can just paint it and do other things, but I'm curious about the plastidip since I will be getting some anyway.
OrzechNJ Posted September 16, 2013 Report Posted September 16, 2013 imo its a good idea.. but u have to make sure that theres no dents and sand it real good.. sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
Agreene Posted September 16, 2013 Report Posted September 16, 2013 you can do it but id I think using trunk liner on a box looks the best. gives it a sparkly charcoal look pretty sure you can just get trunk liner in a spray can
Brandonbkd Posted September 16, 2013 Report Posted September 16, 2013 Just be careful nothing rubs it as it'll wear easily FI BL18 Build Log: CLICK HERE!! 2003 Explorer Sport: FI BL18 SoundQubed 2200 at 0.7ohm Pioneer DEH-2500UI Pioneer 6 x 8s Rockford Fosgate 6 x 9s 5 ft^3 box at 35hz Lots of Mega Mat
jmfrb1 Posted September 16, 2013 Author Report Posted September 16, 2013 you can do it but id I think using trunk liner on a box looks the best. gives it a sparkly charcoal look pretty sure you can just get trunk liner in a spray can I definitely agree with this! What are the steps you took to do this? And thank you guys for the advice.
Agreene Posted September 16, 2013 Report Posted September 16, 2013 you can do it but id I think using trunk liner on a box looks the best. gives it a sparkly charcoal look pretty sure you can just get trunk liner in a spray can I definitely agree with this! What are the steps you took to do this? And thank you guys for the advice. what I have seen done is spraying the box with plain matt black then throwing the trunk liner over.
bbeljefe Posted September 16, 2013 Report Posted September 16, 2013 You can also use Flex Seal, which is more durable than Plasti Dip when sprayed on wood. I Plasti Dipped that console box and sprayed it with Plasti Dip clear. It sat in my shop for a week before we installed it and a few days later, there was paint chipped on top of it. He didn't even know what happened to it. I wouldn't use it on a wood surface again unless I cleared it with urethane and if I was going to do that, I'd just use a simple base coat like I normally do so... no more Plasti Dip on wood for me. That said, I've Flex sealed boxes and that shit holds up very well. You can also get another similar product at Lowe's now that is clear, although I've not used it yet. I have a can and will be trying it though... Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
DylanBunch Posted September 16, 2013 Report Posted September 16, 2013 Don't do it. I did it and it did not work well, peel very easy on wood 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
jmfrb1 Posted September 16, 2013 Author Report Posted September 16, 2013 What if you were to throw a coat of fiberglass resin on it first
bbeljefe Posted September 16, 2013 Report Posted September 16, 2013 The box I used it on was sprayed with automotive urethane primer and wet sanded with 600 grit paper before it was Plasti dipped. Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
