Do people still do this.
ham4864
I remember years ago when i mounted my amp to my sub box. I have seen people do this and i heard it was a bad thing to do.
I have seen a guy use a few layers of wood on the box then mount the amp to that.
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
I mean i know that,i don't want my amp/amps to fail
2009 bmw 5 series
Head Unit Stock
I do it. As long as you don't have box flex it's fine. If you do, you should brace your box anyway. For me: My box is the thing that moves the least in my vehicle lol
I see people using rubber bushings between the amp and box to dampen the vibration. I'm sure that helps a little bit, but why not just built an amp rack? It will look a lot better and protect the amp.
Did you get that scar tissue when you got your vagina installed?
KNOWLEDGE DESTROYS FEAR Measure twice, cut once
JVC touchscreen HU Mmats E600.4
Realm L56c Audiophile 6.5 comps up front JBL P963 rear deck PB RTA 112 trunk CE Auto Big 3 Mechman 240alt D'Amore VM-1
Quick word regarding rubber bushings: Those don't do anything unless you put bushings on the backside of the screw too. And use a screw with an unthreaded shank so the threads don't grab on the amp
thats a good tip
2009 bmw 5 series
Head Unit Stock
Mine aren't mounted to my box directly.. But the only way I could mount my amps was to build a rack at an angle and attach it to the box. I went to lowes and got a hot water line insulator, put it between the amp rack and the box. It still vibrates some but now as much as it did. I had absolutely no other room.
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
People say it's ok as long as there's no box flex but I have to disagree. Sit on your box for a couple songs and see if you find it comfortable. If it is, go ahead. If not, then I wouldn't.
Not the flex, the vibrations
  • Who's Online   0 Members, 0 Anonymous, 314 Guests (See full list)
