Cox Posted September 19, 2013 Report Posted September 19, 2013 I now have a xs d3400 up front and an xs xp3000 in my trunk. Do I have to do any certain thing to charge them now like disconnect them from each other or anything like that? Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
inferno1985 Posted September 19, 2013 Report Posted September 19, 2013 if the battery in the trunk is low on juice and you wan it charged id throw it on charger on a slow charge to juice it up, otherwise im sure you can just hook it up along with the other battery. if thats what your asking. i dont see why you would need to charge them separately unless the xp has been sitting on a shelf not in use for sometime.
tacomaguy1 Posted September 19, 2013 Report Posted September 19, 2013 charge with both connected....do not charge over 14.4v per xs instructions Team Flex Issues
Kyblack76 Posted September 19, 2013 Report Posted September 19, 2013 charge with both connected....do not charge over 14.4v per xs instructions werd fused, at both ends... please. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Cox Posted September 19, 2013 Author Report Posted September 19, 2013 charge with both connected....do not charge over 14.4v per xs instructions werd fused, at both ends... please. they are dont worry Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
SnowDrifter Posted September 19, 2013 Report Posted September 19, 2013 They are wired in parallel. So when you charge one, it charges the other. Set it and forget it, nice and easy ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
