rockford 1200.1D is melting wires.
whatusay45
Damn we live in the same state just 5 hours away....
http://www.amazon.com/Rockford-Fosgate-RFK1-Power-Install/dp/B00148Z9Y4/ref=sr_1_3?ie=UTF8&qid=1380306566&sr=8-3&keywords=rockford+1%2F0
If i bought that.. ran it to the rear battery do you guys think it would be ok ? or do I have to litteraly tear my whole system apart and redo all of the wiring? Because that's what im thinking about doing.
what else would i need ? it comes with an ANL fuse holder..
Or would i rather get
http://www.ebay.com/itm/50-ft-Spool-1-0-Gauge-AWG-RED-Power-Ground-Wire-Sky-High-GA-ft-/281133321948?pt=US_Car_Audio_Power_Speaker_Wire&hash=item4174da0edc
from sky high ? its CCA but it should handle 250 A?
You have some safety issues so at this point I would tear it all down until you can do it safely. The first thing would be to do the big 3. Then work your way back.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
yes the shca cca 1/0 handle 250 amps thats what I run the reason I pick cca is because I'm only running 1 amp its a 05 t1000bd it has a 150 amp fuse so 1/0 cca is plenty
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
I would tear it out. Send me a pm and them make that 5hr drive to get it all fixed lol... If you decide you would want to send me a pm I will help you get everything you need
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
  • 1 month later...
SOOO.. after a while of saving.. i ended up purchasing a spool of SHCA 1/0 OFC to replace my RF OFC 4 gauge.. but then i noticed my lights would dim alot worse then when i had the RF 4 gauge so i went ahead a tore all my set up apart again... took a multiplier and noticed my
voltage would drop from 13.2v charging to 11.3v .. yikes.. so it think its about time to do the big three.. and buy a third battery.. but for now the big three
Did you sand the ground on the first pic here? I see its a factory ground, but my factory ground on my explorer had paint, was JW. Also the big 3 its pretty simple, i dont think there is a set guide to the big 3 for specific cars. A run from Batt+ to Alt+, A run from Batt- to Frame/Body (preff. both imo) and a run from Batt- to Engine (I used alt bracket for mine).
02 Dodge Durango
1 Fi SP4 18" .v2
Sundown SCV3k @.5 Ohms
XS D3100 up front
Northstar SMS AGM 400 in the back
All XS Power 0ga OFC
240a Apex h/o alternator
Pioneer AVH-X2500BT HU
Dual 0ga runs from the alt to battery
Dual 0ga runs from battery to amp
KnuKoncept makes good fuse blocks but you have to know how to install the wire the right way in them. I run there battery terminals and you need to be good at installing the wire into the compression fitting. Been running them for over a year no issues at all.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
  • Who's Online   0 Members, 0 Anonymous, 1467 Guests (See full list)
