rockford 1200.1D is melting wires.
whatusay45
I have a 1200-1d running at 1 ohm.. the amplifier was fine before at 4 ohms. But now its melting my 4 gauge CCA wire and going into protection mode. I have another fosgate 1200 completely identical running off of the same electrical and It is doing fine.
You have two of them running at the moment but only one is having issues? Pictures?
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
yeah sounds like a ground issue
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
amp is bad or the current draw is exceeding the capability of your cca wire or you have a loose connection causing resistance to climb what kind of fuse holder are you using?
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
  • Who's Online   1 Member, 0 Anonymous, 747 Guests (See full list)
