Hatch rattle, best way to fix?
Yeah I think I would rather use real sound deadener and then buy that stuff for touch up spots or something. I'm sure it works but it probably depends on how bad the problem is to begin with. If I had to guess it's probably pretty good for making plastic parts heavier if you keep layering it on but not so much metal.
That tubing is a great idea though. Easily removable if I run into problems too.
I know this is kind of late to reply but I have heard of getting that foam tube piping cover stuff (http://www.homedepot.com/p/Armacell-1-in-x-6-ft-Tubolit-Self-Seal-Foam-Pipe-Insulation-OES11838/100565309#.UlGHCybD81I) and put it on your rubber seal it should create a little more cushion between the hatch and your car. and I would definitely use some sound deadener. it helps a whole bunch. if you want some cheap sound deadener I would use this (http://www.lowes.com/pd_154017-81326-PS625_0__?Ntt=peel+and+seal+roofing&UserSearch=peel+and+seal+roofing&productId=1018733&rpp=32). and it works just as good as all those other sound mats.
Would that peel and seal stuff be good to line your trunk with to stop rattling?
Check out my Youtube channel www.youtube.com/user/ologiic
peel and seal fucking sucks money dick.
its MADE FOR THE ROOFS OF HOUSES. not for your friggin car.
somebody did a test of that stuff vs second skin damplifier pro and they found out that it took like 5 layers of PnS to equal the deadening properties of one layer of damp pro. the cost was equal i think.
want cheap good deadener? audiotechnix.
oh, and if you want to take PnS off, good luck getting the brown residue off the paint from the asphalt based adhesive. it will stay there forever.
.im pretty sure it was 25% coverage of real deadener to 5 layers of p&s iirc
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
Had same issue here on 96 grand Cherokee. Use weatherseal tape from lowest or H.D. 3/4 INCH. Use sound deadener on back of license plate also.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
wish you the best of luck if you use that peel and seal.. Don't cheap out and get that crap,there are some decent priced deadeners out there like audio technix,stinger,etc. second skin is really good but in no way cheap.
it depends. whats rattling and do you have a car trunk, hatch or what?
The trunk, I have a 2006 Pontiac G6 Gt.
I would definitely put sound deadener on entire trunk. and if you have that spoiler/wing on trunk I would try to take it off and put either foam, rubber, or even sound deadener on the spot where it comes in contact with trunk. but not 100% positive because I have never had to deal with that. Also you might want to deaden the back dash, I did and it does help. and put a foam sheet or deadener on license plate. they like to rattle.
AQ - SQ For Life
