2010gmc Posted October 7, 2013 Author Report Share Posted October 7, 2013 So do you think I would be fine with my current battery and a d3400 for the crescendo at .5 ohms? Link to comment Share on other sites More sharing options...
CleanSierra Posted October 7, 2013 Report Share Posted October 7, 2013 Don't run .5 ohm dude, just don't. Once you have some experience under your belt, MAYBE. Even then, I'm not a fan. As far as batteries go, is not recommended to mix a lead acid battery with an AGM. The batteries will equalize at a lower voltage than the AGM wants. So over time, it's putting stress on the AGM battery. The same battery you paid a couple hundred bucks good, so is it worth it to shorten that batterys life? Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
2010gmc Posted October 7, 2013 Author Report Share Posted October 7, 2013 Ok I'm just going to do 2 subs, hopefully 10's will fit. How many feet of wire do you think I'll need for power and ground wire Link to comment Share on other sites More sharing options...
2010gmc Posted October 7, 2013 Author Report Share Posted October 7, 2013 Ok the guy said he could do 10's with about 1.2 cubes per sub. Would that be good? Link to comment Share on other sites More sharing options...
john253a Posted October 8, 2013 Report Share Posted October 8, 2013 Amp q1-2200 $429 (free shipping) http://www.soundqubed.com/Q1-2200D_p_31.html D2 sa8v2 $185 http://www.emfcaraudio.com/sundown-audio-sa8v2-dual-2/ $1169 +batt and box Extra batt http://www.sonicelectronix.com/item_38730_XS-Power-D3100.html (didn't shop around so may be cheaper elsewhere) Link to comment Share on other sites More sharing options...
john253a Posted October 8, 2013 Report Share Posted October 8, 2013 The 10's you'll need to fire at the floor and you'll be restricted on mounting depth If your going the 10'a look at the sd series Link to comment Share on other sites More sharing options...
2010gmc Posted October 8, 2013 Author Report Share Posted October 8, 2013 When you say I'll need to fire the 10's at the floor do you mean because I can't fit them forward firing? And if I could fit them forward firing would 1.2 per sub work well? Link to comment Share on other sites More sharing options...
john253a Posted October 8, 2013 Report Share Posted October 8, 2013 If you want to fit 4" spacers then you can go fwd Without they'll be down If you go fwd go with sa10 or x10 depending on what u can fit And 1.2net is too much Aim for 0.9-1net each ported Link to comment Share on other sites More sharing options...
2010gmc Posted October 9, 2013 Author Report Share Posted October 9, 2013 What would be the best tuning frequency for 2 sa8's? I obviously want to hit the lows hard but I also don't listen to music that's going to go insanely low. I definitely want to be able to hit 30 hz pretty loudly, but I guess going lower than that is not a big deal. It would be awesome to be able to hit in the 20's but I don't want to tune for that if I'll lose output in the 30's and up Link to comment Share on other sites More sharing options...
CleanSierra Posted October 9, 2013 Report Share Posted October 9, 2013 Dude this forum is FULL of information. Have you tried using the search feature to check and see what people are tuning their boxes to? You also need to know some limitations with your requirement.You are NOT going to get a ground pounder with a couple of 8s, or shallow mount 10s. 33-37Hz is a good all around tune in a truck like yours for most music listening types of music. If you tune so low, you'll need one HELL of a midstage to pick up where your sub stage falls off. SA8s sound great and that have a LOT of output for being so small. At the end of the day though, you aren't going to have a system that will be heard for blocks. It WILL impress people that you only have a couple of 8s because they sound awesome. I dint want you to get your hopes up, our think that you can destroy 38Hz and also get much output in the 20s though, there will be a compromise with your tuning. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
