Elemental Designs NINe.1 Questions
Bence
I just purchased an elemental designs NINe.1 amplifier for my car. It will be running a single Arc Audio Black 12" Sub with Dual 4ohm voice coils. My question is I thought this amp was a single channel amp.... However there are two set's of speaker outputs on the amp. I have searched for the owners manual and not been successful as ED is out of business. Here is a link to the auction so you can see the pictures of the amp.http://www.ebay.com/itm/Elemental-Design-Nine-1-Amplfier-/251341385439?_trksid=p2047675.l2557&ssPageName=STRK%3AMEWAX%3AIT&nma=true&si=l7msPp7pQpWWWEoA8zcP4xMHos0%253D&orig_cvip=true&rt=nc
Does anyone know which positive and which negative I need to use to run my sub? I have the sub wired in the box to be at a 2 ohm load.
I have never had an amplifier with both a sub sonic filter and a low pass filter so I honestly don't know how to set this amp up. It also has a setting to change the phase. I have a DD-1hv to set the gain's and make sure I don't have any distortion. I also have the CC-1. Any tips on how to set this amp up would be awesome!. I've read until my head hurts and just don't seem to understand the subsonic filter or the phase. I understand the frequency response setting for the most part :(
It is one channel just has two terminals
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Why would there be two positive out's and two negative out's? I don't understand sorry. On an two channel amp you use the positive from one channel and the negative from the other channel to bridge the amp and run it in mono. Most of the amps that do that will have a diagram of which positive and negative from each channel to use.
Whats so hard to understand? Two sets of terminals. Oje channel. Use any positive you want any negative you want it all goes to the same place. Its done for wiring ease.
Subsonic set 5 hrz below your box tuning.
Low pass filter set at about 80 or 100 depending on your interior speakers abilities.
Dont over think it. Its all reslly simple stuff and there sre more than enough resources available to helpyou if you get stuck.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Why has there been 1501 posts about the "two channel" mono amps? Lol
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
So I'm a bit slow... What is the box tuning? It's an Arc Audio Black 12" Sub in a sealed enclosure with 1.2 cubic feet of airspace. That's where I get lost. Also the CC-1 and DD-1 both say to set the crossover to it's lowest setting... Does that mean the lowest number or the highest number?
Sealed enclosures don't have a tuning.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
it's 15 Hz not KHz and put somewhere around 30.
So where do I leave the subsonic filter adjustment? 15khz or 50khz?
15khz is 15000hz.
i think you mean 15hz or 50hz.
just put it to like 30hz or something like that.
  • Who's Online   0 Members, 0 Anonymous, 656 Guests (See full list)
