Nikitaaa Posted September 29, 2013 Report Posted September 29, 2013 Is it really that hard to comprehend? SPACED SPIDERS One set is still glued to the basket ( the set that HE glued down to the basket while reconing) Is 100% intacted. The glue joint that failed, he did not do. Aq/the build house did it. Nakitta How the hell can you even sugest that? You do realize he would have to remove the surround, right? And if he used CA the surround wont be comming off in one piece. Best option is to load it with glue, clamp it and activate it I assumed the part of the spider that he glued was coming part.And yes lol, I realize that is involved. Usually when a spider is coming unglued, you're screwed anyways so do what you can. I had to do the same process that I stated above when my spider came unglued after a recone. Reglued /shimmed everything and it's still functioning. Even though I understand now it doesn't apply to this scenario, it's not that crazy of a thing to do. Just have a sharp box cutter and some steady hands. 2007 M/T Honda Civic Coupe EX (4) Sundown Audio X-8's (2) Ampere Audio 3800.1's (3) Stinger SPV-44 Batteries (1) Mechman 240 3:1 Ratio 4th order sealed from the trunkTEAM NWSPLBest termlab scores to date in Honda trunk:151.7db legal (official) IASCA trunk 3 classBest termlab scores to date in my walled Subie:152.9db legal (unofficial) IASCA advanced 2 class155db outlaw
fox_racin4 Posted September 29, 2013 Report Posted September 29, 2013 As long a spider sits flat youll be good. Just dont be shy with glue, thats why it broke. Technically it would be their fault since A. They didnt glue it properly. B. didnt line the holes up or spacer screws. But if enough glue was used the screws wouldnt even be needed 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
big dee Posted September 29, 2013 Report Posted September 29, 2013 When reconing these subs can we just take the plastic ring off ? I'm not a fan of those rings at all
bassaddiction Posted September 29, 2013 Author Report Posted September 29, 2013 When reconing these subs can we just take the plastic ring off ? I'm not a fan of those rings at all i hated it the first time i saw it but it was glued on already who knows when that will come off
bassaddiction Posted September 29, 2013 Author Report Posted September 29, 2013 As long a spider sits flat youll be good. Just dont be shy with glue, thats why it broke. Technically it would be their fault since A. They didnt glue it properly. B. didnt line the holes up or spacer screws. But if enough glue was used the screws wouldnt even be needed
